Tension, horizontal & vertical tension
The problem involves a mass suspended by two ropes: one vertical and one horizontal. The mass is stated to be hanging straight down, and the inquiry focuses on determining the tension in each rope, given the mass of 800 kg.
  • Participants discuss the use of free body diagrams to visualize forces acting on the mass. Questions arise regarding the meaning of the tension in the ropes when the mass is hanging straight down. Some express confusion about the role of the horizontal rope in this scenario.
Participants are actively engaging with the problem, exploring various interpretations of the forces involved. Some have offered guidance on considering equilibrium and the directions of tension, while others express uncertainty about the implications of the horizontal rope's tension.
There is mention of a diagram that some participants have drawn, but there are also indications of missing information regarding the setup and the role of the horizontal rope when the mass is hanging vertically.
Shortyyy
A mass Z is suspended by a vertical rope attached to the roof, and a second rope attached horizontally to a wall.
what is the tension in each rope if Z is hanging straight down?
What are the rope tensions?
Suppose Z has a mass of 800kg. what is the tension in the pair of ropes?
These questions have me stumped!
ANy help appreciated!
I'd start by drawing a free body diagram, or posting the diagram if one is give.
Also what does this mean?
Shortyyy said:
what is the tension in each rope if he is hanging straight down?
Sorry, I stuffed it up. fixed.
I have drawn a basic diagram but just do not know the formulas etc
Thanks.
Thanks.
Post your diagram.
(Upload it to http://imageshack.us" and copy & paste one of the forum board URLs)
http://img529.imageshack.us/img529/6206/98546679.png
Sorry, its just a quick mockup in paint of what I have on paper.
uhm what are those things in green?
Vectors? - Gravity, equilibrium, constructed vectors for the ropes?
Am i wayyyy off track?
Well normally if it is hanging straight down, I don't see the point in the second horizontal rope. But given the problem, I can only tell you to draw in the forces acting and then use the fact that it is in equilibrium to get the tensions.
This is the bit I am having trouble with.
So the forces acting would be gravity pulling Z down, which needs an equal and opposite vector for equilibrium (upward). the vector of the diagonal of the parallelogram?
Its got me royally stumped.
Well if you remove all the green for the moment, you just have the ropes and the mass.
Now acting on the mass (vertically), there is tension and weight (you know that acts downwards). So what direction should the tension act in this rope?
Similarly, horizontally, there is only tension acting.
Vertically the direction of the tension in the rope should be upward.
Horizontally the tension in the rope should be acting toward the wall?
Yes that is correct. So if vertically the mass does not move, what is the resultant force in the vertical direction? (Do the same horizontally)
So the tension on the vertical rope is 9.8N? same for the horizontal?
i'm confused with the horizontal one
i think there is only one force on horizontal direction which is tension towards the wall.
if so, then the system isn't in equilibrium
Precisely why the horizontal force is zero =)
oh, i see
hahahahahaha
but in fact i think it's possible to construct such system. I hang the mass and add a horizontal string which has a certain value of tension
songoku said:
oh, i see
hahahahahaha
The horizontal string won't have any tension value unless you intentionally tighten it up and induce a value in it, in which case the mass and the upper rope will swing in toward the wall at a certain angle, but that's a different problem.
Well yes, you can add the horizontal string, but if the mass is hanging vertically downwards, that must mean the horizontal string isn't taut.
thanks for the explanation ^^
  • · Replies 38 ·
  • · Replies 18 ·
10K
  • · Replies 22 ·
