How Does Rope Tension Vary Along Its Length and Affect Wave Speeds?
  • Thread starter Thread starter bowma166
    Rope Tension
The discussion focuses on calculating the tension in a flexible rope of length l and mass m that hangs between two walls, with specific attention to the tension at the ends (T1) and the middle (T2) of the rope. The tension at the ends is derived as T1 = mg/(2cos(α)), while the tension at the middle is calculated using T2 = (mg/2)tan(α). The speeds of transverse waves at the ends and middle are also determined, resulting in v1 = √(gl/(2cos(α))) at the top and v2 = √(2gR) at the bottom. These calculations are essential for understanding wave propagation in a sagging rope.
  • Understanding of basic physics concepts such as tension and wave speed.
  • Familiarity with trigonometric functions and their applications in physics.
  • Knowledge of calculus, specifically limits and derivatives, for analyzing tension at infinitesimal points.
  • Ability to apply Newton's laws of motion to static and dynamic systems.
  • Study the derivation of wave speed in different mediums, focusing on the formula v = √(T/μ).
  • Explore the implications of tension variations in non-linear systems, particularly in flexible materials.
  • Investigate the effects of different angles (α) on tension and wave speed in ropes and cables.
  • Learn about the applications of tension calculations in engineering, particularly in structures and materials science.
Physics students, mechanical engineers, and anyone interested in the dynamics of flexible materials and wave propagation in ropes and cables.
bowma166
A flexible rope of length l and mass m hangs between two walls. The length of the rope is more than the distance between the walls, and the rope sags downward. At the ends, the rope makes an angle of \alpha with the walls. At the middle, the rope approximately has the shape of an arc of a circle; the radius of the approximating (osculating) circle is R. What is the tension in the rope at its ends? What is the tension in the rope at its middle? What is the speed of transverse waves at the ends? At the middle?
v=\sqrt{\frac{T}{\mu}}
Well, at the ends, it's kind of easy I think. Each end needs to support half the weight of the rope, so the force acting straight down on the end is \frac{1}{2}mg. We want to know what force in the rope would create that vertical force, so...
\cos{\alpha}=\frac{\frac{1}{2}mg}{T_1}
T_1=\frac{mg}{2\cos{\alpha}}
The tension in the middle is where I have troubles. I started by looking at a segment of the rope of length s at the bottom of the rope. The force required to keep this up is equal to m_s g, which, with \mu equal to the mass per unit length of the rope, is equal to
\mu sg = \frac{mgs}{l}
This force is exerted at an angle \theta above the horizontal, so the force exerted on a segment s by both rope sections becomes:
F=\frac{mgs}{l\sin{\theta}}
The formula for arc length is s=R\theta... But, in this case, the angle from the center of the approximating circle that subtends the arc of length s is equal to twice the theta that the rope makes with the horizontal at the ends of the arc (I wish I had a diagram to show you...), so: s=2R\theta. The formula for the force then becomes:
F=\frac{2mgR\theta}{l\sin{\theta}}
The tension in the rope is equal to this force at the infinitesimal point at the very bottom, so...
T_{2}=\lim_{\theta\to0}\frac{2mgR\theta}{l\sin{\theta}}
T_{2}=\frac{2mgR}{l}\lim_{\theta\to0}\frac{\theta}{\sin{\theta}}
That limit is equal to 1, so,
To find the velocities we just need to plug that into the equation
v=\sqrt{\frac{T}{\mu}}, with \mu=\frac{m}{l}
Getting:
v_1=\sqrt{\frac{gl}{2\cos{\alpha}}} at the top
and
v_2=\sqrt{2gR} at the bottom.
So, I got answers for everything, but I have absolutely no idea if they're any good. I'm just wondering if I did this right. Thanks!
Bump.
Bump.
This problem sucks, I know. :\
You have found tension in the ends.
Let tension in the middle = T2
I do not know what is the meaning of tension in the middle. Does it mean tension exactly at the mid point? If so, then following will work: -
Consider the left half of the rope as the system under consideration. The forces on the system are
1. Weight mg/2 downward
2. Tension T1 at the left end at angle alpha with the vertical
3. Tension T2 at the bottom end towards right.
For horizontal equalibrium,
T2 = T1 sin(alpha)
T2 = mg/(2 cos(alpha)) * sin(alpha) = (mg/2)*tan(alpha)
  • · Replies 18 ·
9K
  • · Replies 22 ·
