Tension in an object moving with circular motion
7 replies · 2K views · last reply
Nat Reed
An object of mass 0.8kg is whirled round in a horizontal circle of radius 2m with a constant speed of 15ms-1. Calculate the tension in the string.
So far I have calculated that the angular velocity is 7.5rads-1, the frequency is 1.19Hz and the time period is 0.84s, I'm just not sure where to go from here.
Where did the relevant equations section go?
You didn't need to find angular velocity, frequency or period.
There is a single equation you can use to find tension from the given variables.
Have you drawn a free body diagram? Do you know an equation for calculating the acceleration of the object?
Looks like you have everything you need in terms of variables
See if there is an equation that can use these variables to calculate centripetal acceleration
Draw the FBD and analyse the forces acting on the body.
Then frame an eqn. of horizontal and vertical eqbm.
U can get the required ans
darmzynyolarh said:
Plz i nid formula to dat first question
What are your thoughts on this so far? Can you say in words what is happening physically in this problem?
