Tension is horizontal rope tied to hooks at each end
4 replies · 5K views
Jwill
Want to make sure I'm doing this right... it seems too easy
A horizontal rope is tightly tied to hooks between two walls separated by a distance of 5m. A 100N weight is suspended from the middle of the rope and it sags so that the middle of the rope is displaced a distance of 0.25m.
a. What is the tension in the rope?
b. What are the horizontal and vertical forces exerted on the hooks.
I found the angle using arcTan(.25/2.5) = 5.7106 degrees. Then did 100N/tan(5.7106)=1000Ni and used sqrt(100N^2 + 1000N^2)= 1004.988N to find the rope's tension...
The tension is half that... the vertical component of tension on either side of the weight has to be 50N.
So that would also make the horizontal forces on each hook 500N right?
