Tension, pulley and acceleration problem
The problem involves two blocks connected by a cord over a frictionless pulley, with masses m1 = 3.3 kg and m2 = 5.1 kg. The correct acceleration for both blocks is calculated to be 2.1 m/s². To find the tension in the cord, it's essential to apply Newton's second law to each mass separately, using their respective free body diagrams. The weight of each block has been calculated, and the net force is determined by subtracting the lighter block's weight from the heavier block's weight. Understanding the forces acting on each mass will lead to the correct tension calculation.
sphykik
In the figure below (part a), two blocks are connected by a lightweight, flexible cord that passes over a frictionless pulley.
(a) If m1 = 3.3 kg and m2 = 5.1 kg, what are the accelerations of each block?
(b) What is the tension in the cord?
I got the acceleration, a, to be 2.1, which is correct, but I cannot figure out how to get part b. I found the weight in Newtons of the 5.1 and 3.3 blocks, and then subtracted and used F=MA to find the acceleration. Can someone point me in the right direction about the tension? Thanks!
maybe i didnt provide enough info... i found the weight in Newtons for the 5.1kg weight to be 49.98N, and 32.34N for the 3.3kg weight. I subtracted and got 17.64N. I did F=MA, with F being 17.64, m being 8.4 (or 5.1+3.3) and found a to be 2.1. Now I can't seem to find out how to do the tension part...
Thanks in advance for the help!
In order to find the tension you need to consider each mass separately and apply Newton's 2nd law. It looks like the free body diagrams for each mass are already given--translate them into equations and solve together. (Or, since you have the acceleration, you can just analyze one of the masses.)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 102 ·
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 47 ·
