Reduce 3x3 Matrix to Scalor Quantity - Help Needed
To reduce a 3x3 matrix to a scalar quantity, the trace, which is the sum of the diagonal elements, is a common method. However, in this case, the matrix represents a tensor related to the moment of inertia for a wheel design. The values correspond to the components of the inertia tensor in an outer coordinate system. To obtain a single scalar value, further clarification on the tensor's context and the specific calculation method is needed. Understanding the tensor structure is essential for accurate reduction to a scalar.
frasool
Hi
I have the following tensor and i need to reduce to a scalor quantity:
3 by 3 matrix
4150470.48 , 317.64, -353.42
317.64, 2047101.07,-1407556.61
-353.42, -1407566.61, 2284136.55
Please its urgent and any help would be greatly appreciated!
Regards
Faizan
First, a matrix is NOT a tensor- just as a sequence of numbers is not a vector. A matrix can represent a tensor but you have to have some tensor space structure and you haven't told us HOW that matrix represents a tensor (i.e. what basis you are using).
The simplest way derive a single number from a matrix is the contraction- in terms of a matrix representation, it is just the "trace": add the numbers on the main diagonal. But surely there is more to this than just getting some number from the matrix?
hey thanks for ur reply!
I got these values from solidworks but for my wheel design i need a single value for the moment of inertia. The values i gave you represent Ixx Ixy Ixz and then Iyx Iyy Iyz and Izx Izy Izz. And it says these were taken from the outer coordinate system!. So its not just a matrix it is a tensor. Could you help me out with how to proceed with this problem !
Regards
Faizan
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 131 ·
9K
  • · Replies 0 ·
