Test whether the integer is a prime
  • Context:
  • Thread starter Thread starter evinda
    Integer Prime Test
96 replies · 12K views
evinda
MHB
Hello! (Wave)
We want to find an efficient algorithm that checks whether an odd number is a prime or not.
In order to obtain such an algorithm, one tests the congruence $(X+a)^n \equiv X^n+a$ not "absolutely" in $\mathbb{Z}_n[X]$, but modulo a polynomial $X^r-1$, where $r$ have to be chosen in a clever way. That is, one compares, in $\mathbb{Z}_n[X]$, the polynomials
$$(X+a)^n \pmod{X^r-1} \text{ and } (X^n+a) \pmod{X^r-1}=X^{n \mod{r}}+a.$$
In the intermediate results that appear in the course of the computation of the power $(X+a)^n$
, all coefficients are reduced modulo $n$, hence they can never exceed $n$. Calculating modulo $X^r-1$ just means that one can replace $X^s$ by $X^{s \mod{r}}$, hence that the degrees of the polynomials that appear as intermediate results can be kept below $r$. This keeps the computational cost in the polynomial range as long as $r$ is $O((\log{n})^c)$ for some constant $c$.
How do we compute the computational cost for computing $(X+a)^n \pmod{X^r-1}$ ? (Thinking)
Mathematics news on Phys.org
Hey evinda!
What does $r$ is $O((\log{n})^c)$ mean? (Wondering)
That depends on the algorithm we use doesn't it?
We might for instance set up a recursive algorithm based on squaring.
In that case let $f(n,r)$ be the computational cost of evaluating $(X^{r-1}+b_{r-2}X^{r-2} + ... + b_0)^{n} \pmod{X^r-1, n}$.
Then:
$$f(2k,r)=f(k,r)+\text{ cost to evaluate }(X^{r-1}+b_{r-2}X^{r-2} + ... + b_0)^2$$
and:
$$f(2k+1,r)=f(2k,r)+\text{ cost to evaluate }(X^{r-1}+c_{r-2}X^{r-2} + ... + c_0)(X^{r-1}+b_{r-2}X^{r-2} + ... + b_0)$$
Can we find the worst case computational cost for computing $(X+a)^n \pmod{X^r-1,n}$ from that? (Wondering)
I like Serena said:
Hey evinda!
I assume that we will find the computational cost in respect to $r$ and then we will deduce that the computational cost is polynomial only if $r=O((\log{n})^c)$. (Thinking)
We use fast exponentiation in the ring $\mathbb{Z}_n[X]$.
So, $f(n,r)$ will be the computational cost of evaluating any monic polynomial of degree $r-1$ ?
I like Serena said:
Then:
and:
I see...
Do we multiply two polynomials of some degree $d$ using the FFT, the time complexity of which is $O(d \log{d})$ ?
If so, will we have a recursive relation of the following form? (Thinking)
$f(n,n)=\left\{\begin{matrix}
f\left(\frac{n}{2},n \right )+O\left(\frac{n}{2}\log{\left(\frac{n}{2} \right )} \right ), & n \text{ even} \\
f\left(\frac{n-1}{2},n \right )+O\left(\frac{n-1}{2}\log{\left(\frac{n-1}{2} \right )} \right )+\dots, & n \text{ odd}
\end{matrix}\right.$For the case when $n$ is odd, how do we multiply a polynomial of degree $n-1$ with a polynomial of degree $1$ ? Do we use again the FFT?
Isn't $r$ supposed to be a constant?
Yep. (Nod)
I guess we can. (Mmm)
Shouldn't that be:
$$f(n,r)=\begin{cases}
f\left(\frac{n}{2},r \right )+O\left(r\log{r} \right ), & n \text{ even} \\
f\left(n-1,r \right )+O\left(r\log{r} \right ), & n \text{ odd}
\end{cases}$$
(Wondering)
We don't.
First we evaluate the left hand polynomial completely, yielding a polynomial of degree $r-1$.
And then we multiply by the right hand polynomial of degree $r-1$.
We can indeed use the FFT for that. (Happy)
Yes, it just says at the beginning that $r$ will have to be chosen in a clever way. So they mean that we have to pick an $r$ in the order $O((\log{n})^c)$, or not? (Thinking)
I like Serena said:
Shouldn't that be:
\end{cases}$$
(Wondering)We don't.
Isn't it as follows?
$(X+a)^{2k+1} \mod{(X^r-1)}=((X+a)^k)^2 \cdot (X+a) \mod{(X^r-1)}$
So don't we multiply a polynomial of maximum degree $r-1$ by a polynomial of degree $1$?
Or am I wrong? (Thinking)
I don't know what that is supposed to mean. I was hoping you could clarify. (Worried)
Or am I wrong?
Oh yes, the right side polynomial is always $(X+a)$. (Mmm)
That means we can calculate it directly:
$$(X^{r-1}+b_{r-2}X^{r-2} + ... + b_0)(X+a) \\
= X^r + (b_{r-2}+a)X^{r-1} + (b_{r-3}+a)X^{r-2} + ... +(b_1+a)X+b_0a \\
= (b_{r-2}+a)X^{r-1} + (b_{r-3}+a)X^{r-2} + ... +(b_1+a)X+(b_0a + 1)
It takes $r$ additions, so it's $O(r)$.
It doesn't really matter though. We might as well use the same FFT for $O(r\log r)$.
That's because $O(r\log r + r)=O(r\log r)$. (Thinking)
It says the following:
(Thinking) But as they write it, they mean that the computational cost is polynomial only if $r$ is $O((\log{n})^c)$. I don't know why they say it like that. (Thinking)
So don't we have the following?
f\left(n-1,r \right )+O(r), & n \text{ odd}
\end{cases}$$
Also, I was wondering if it is not possible that the polynomial that we get has degree $<r-1$... (Thinking)
In addition, we also need an initial condition in order to be able to solve the recurrence relation, don't we?
Do we check the computational cost when $n=r$, in order to find an initial condition? Or am I wrong? (Thinking)
It actually says 'if $r$ is of size $O((\log{n})^c)$'.
So I believe they're not talking about computational complexity but just about which constant value of $r$ to pick.
In particular that affects that number of different values of $a$ that we have to check.
Anyway, we're currently only talking about the computational complexity for a single value of $a$. (Thinking)
\end{cases}$$
Yep.
A degree $<r-1$ can happen in some of the iterations, but not generally.
And it does not matter for the worst case computational complexity.
Indeed, we need an initial condition.
As the algorithm is now, we can only stop when $n=1$ can't we? (Wondering)
Otherwise we don't actually have the polynomial yet.
And then there is nothing to do, so the computational complexity is $0$.
So the computational cost will be polynomial, no matter what $r$ we will pick, right?
It doesn't say how $r$ affects the number of different values of $a$ that we have to check, does it?
A ok.
Ah yes, I see... So we have the following recurrence relation, right?$$f(n,r)=\left\{\begin{matrix}
0, & n=1\\
f\left(\frac{n}{2},r \right )+O(r \log{r}) &, n \text{ even } \\
f(n-1,r)+O(r), & n \text{ odd}>1.
\end{matrix}\right.$$
How can we solve the recurrence relation, now that $f$ is a function of two variables? Do we maybe replace $r$ by $O((\log{n})^c)$ ? (Thinking)
I still don't quite get what is intended.
And as far as I can tell the cost will be polynomial whatever we do. (Worried)
0, & n=1\\
Yep.
We can simplify it:
$$\begin{aligned}f(n,r)&=\begin{cases}
0, & n=1\\
f\left(\frac{n}{2},r \right )+O(r \log{r}), & n \text{ even } \\
\end{cases} \\
&=\begin{cases}
0, & n=1\\
f(\frac{n-1}2,r)+O(r) + O(r\log r), & n \text{ odd}>1
\end{cases} \\
&=\begin{cases}
0, & n=1\\
f\left(\lfloor\frac{n}{2}\rfloor,r \right )+O(r \log{r}), & n >1
\end{cases} \\
&= O(\log n \cdot r \log r)
\end{aligned}$$
Now we can substitute $r=O((\log n)^c)$ if we want. (Thinking)
I like Serena said:
Yep.
We can simplify it:
0, & n=1\\
\end{cases} \\
&=\begin{cases}
0, & n=1\\
\end{cases} \\
&=\begin{cases}
0, & n=1\\
\end{cases} \\
\end{aligned}$$
We have $f(n,r)=f\left( \lfloor \frac{n}{2}\rfloor,r\right)+O(r \log{r})=f\left( \lfloor\frac{n}{4}\rfloor,r\right)+O(2r \log{r})= \dots= f\left( \lfloor \frac{n}{2^i}\rfloor,r\right)+O( i r \log{r})$.
We stop when $\lfloor\frac{n}{2^i}\rfloor=1$. This holds for $i=O(\log{n})$.
So we deduce that $f(n,r)=O(\log{n} r \log{r})$, right?
So we can get that $f(n,r)=O((\log{n})^{c+1} \log{(\log{n})^c})$, right?
Yep.
Furthermore $(\log{n})^{c+1} \log{(\log{n})^c} = O((\log n)^{c+2}) = O((\log n)^{c'})$.
And this is less than linear, which is $O(n)$.
Perhaps we need $r$ of size $O((\log n)^c)$ to achieve less than linear computational complexity instead of polynomial? (Wondering)
I like Serena said:
Yep.
If $r$ is not in $O((\log{n})^c)$ for some constant $c$, then the computational cost cannot be polynomial as for $n$, right? (Thinking)
Suppose $r$ is of size $O(n)$, then $f(n,r)=O(n\log^2 n)$, so that $f(n,r)=O(n^2)$, which is polynomial, but not linear. (Nerd)
Ah right. The fact that $r=O((\log{n})^c)$ is necessary so that the computational cost is polynomial as for the length of $n$, that is $O(\log{n})$, or not? (Thinking)
What is the length of $n$?
Is it the number of digits or some such?
If so then I think that's it. (Mmm)
Yes, I meant the number of digits of $n$. (Nod)
Using the idea described above, we get the following algorithm:
Could you explain to me what the following if-loop checks?
Code:
if (r is a prime number) then
    if (n^i mod r != 1 for all i, 1 <= i <= 4 ceil(logn)^2 ) then
       break;
Code:
       break;
From the context I deduce it's a heuristic criterion that indicates we have found a suitable $r$.
I can't say why it would be suitable though.
Still, we can say a little more about it.
Suppose $n^i \bmod r = 1$, what does that mean?
Isn't there a proposition that looks like that? (Wondering)
Ah, then we have that $r \mid n^i-1$ and so $r$ cannot divide $n$. Right?
So if $r$ is a prime number and $r \nmid n^i-1$ then it is possible that $r$ is a prime divisor of $n$, so in this case we make the further test if $(X+a)^n \mod{(X^r-1)} \neq X^{n \mod{r}}+a$ for some $a$, right?
Actually, we already had that $r$ does not divide $n$, which would have caused the algorithm to terminate (line 4).
But don't we have that $n^d \bmod r = 1$ if $d$ is the order of $n$ with respect to $r$?
And also that $n^{\phi(r)} \bmod r = 1$ if $n$ and $r$ are co-prime? (Wondering)
More specifically, $n^i\bmod r=1$ means that $(n,r)=1$ and $\#n \mid i$.
Oh yes, right...
Yes... (Nod)
With #n you mean the order of $n$, right ?
So according to the algorithm, if $n$ has an order between $1$ and $4 \lceil 4 \log{n}\rceil^2$ with respect to $r$, we can deduce that $n$ is a prime, otherwise we cannot see whether $n$ is prime or composite. Right? (Thinking)
If so, this fact isn't known in general, is it? (Thinking)
Not quite. (Shake)
So if $n^i \bmod r \ne 1$, that means that $(n,r)\ne 1$ or $\#n \not\mid i$ with respect to $r$.
And yes, $\#n$ is the order of $n$ with respect to $r$.
Since we have already checked all lower values of $r$, and since $r\not\mid n$, it follows that $(n,r)=1$.
Therefore $\#n \not\mid i$ with respect to $r$.
Since this is the case for all $i$ up to $4 \lceil 4 \log{n}\rceil^2$, the order of $n$ with respect to $r$ must be higher than than upper bound, and it also means that $r$ has to be greater than that upper bound.
Anyway, it doesn't tell us whether $n$ is prime or not.
It's just a property of $r$ that we can observe, which apparently makes it suitable. (Thinking)
Why does this hold? $A \Rightarrow B\wedge C $ doesn't imply that $A^c \Rightarrow B^c \lor C^c$, does it? (Thinking)
You mean when we get to the last possible iteration of the while-loop, right? (Thinking)
Why does $r$ have to be greater than the upper bound?
Ah the line 9 is executed only if the line 4 is never executed at the while-loop. It doesn't depend on the lines 5-7, right? (Thinking)
Indeed.
But $A \Leftrightarrow B\land C $ does imply $A^c \Leftrightarrow B^c \lor C^c$. (Nerd)
I mean when the condition is satisfied to break out of the loop.
If that condition is never satisfied, we have $r=n$ after the while-loop and the algorithm ends.
Let $N = 4 \lceil 4 \log{n}\rceil^2$.
Then we have $n>N$ with respect to $r$.
Since $r$ is prime, the greatest order $n$ can have, is $r-1$.
Therefore $r>n>N$. (Thinking)
More specifically, the algorithm returns in line 9 if the condition in line 4 was never satisfied, nor the conditions in line 5 and 6. (Nod)
I like Serena said:
Indeed.
A ok. And if $(n,r)=1$ and $\#n \mid i$ then we have that $i=k \cdot \#n$ for some $k \in \mathbb{Z}$ and so it follows that $n^{i} \mod{r}=1$.
I see...
You mean $N=4 \lceil \log{n}\rceil^2$, right?
Ah, so since the greatest order $n$ can have is $r-1$, and we have checked that the order isn't $\leq N$, it holds that $r-1>N \Rightarrow r>N+1$, right? And since we also have that $r<n$, we get the inequality $N+1<r<n$, right? (Thinking)
So, if we find a prime $r<n$ such that $\#n \nmid i, \forall i \in \{1, \dots, 4 \lceil \log{n}\rceil^2 \}$, then we will have found a suitable $r$ to check if $(X+a)^n \mod{(X^r-1)} \neq X^{n \mod{r}}+a$ for some value of $a$. With this value of $r$ and the values of $a$ that we check, we can deduce if $n$ is composite or not. Right?
If we don't find such a prime $r$, then we will have checked that no integer $<n$ divides $n$ and so we will deduce that $n$ is a prime, right?
I like Serena said:
Yes to all of that. (Nod)
Nice. (Smile) I have also some questions about the analysis of the time for the single operations of the algorithm.
About the time for the perfect power test: In my notes, there is mentioned an algorithm which needs no more than $O((\log{n})^2 \log{\log{n}})$ arithmetic operations so that the test in line 1 of the algorithm is carried out.
And I read at an other site the following idea for the perfect power test:
Given a number $n$, if at all it can be written as $a^b$ ($b > 1$), then $b< \log{n}+1$. And for every fixed $b$, checking if there exists an $a$ with $a^b=n$ can be done using binary search.
The logarithm is to base $2$, right? How do we get that $b< \log_2{n}+1$ ? (Thinking)
I like Serena said:
We will have the greatest b when a is smallest.
What is the smallest a? (Wondering)
$2$ ? Then don't we have the following ?
$$n=a^b \geq 2^b \Rightarrow b \leq \log_2{n}$$Can we also find a bound for $a$? Or is it between $1$ and $n$? (Thinking)
Yep. (Nod)
We could calculate $a$ directly with $a=\sqrtn$.
Or we could calculate the upper bound for $a$ by using the smallest value of $b$ giving us $\sqrt n$.
But those are difficult to calculate with an integer algorithm.
So instead we should probably pick $n$ as upper bound so that we need $\log_2 n$ bisections. (Thinking)
