Tested methods to save fuel when driving
  • Thread starter Thread starter wolram
    Fuel Thread
289 replies · 42K views
hmmm... sorry I'm a bit late joining this foray.
You're right. My wife has a Prius and I'm always looking at the mpg readout. I think it makes you drive better. I said that same thing to her not a week ago.
starkind said:
Hmmm.
Consider two otherwise equivalent cars at full stop. One starts out and accelerates slowly until it reaches highway speed one minute later. The other floors the pedal and (no skid marks) reaches highway speed in ten seconds. They both drive to the end of a sufficiently long course, and then stop. Do they both use the same amount of gas?
Moving the same mass the same distance means the same amount of work?
Then the best move would be to accelerate to speed in as short a time as possible, keeping in mind safety.
mtworkowski@o said:
listen. you burn more gas accelerating quickly. F=MA The motor developes more hp and moves the car faster over time. sheeeesh
And you would get there faster, spending less time burning fuel. F=MA is not the reason going faster over the same distance requires more energy, it is the exponentials in the air drag and mechanical resistance equations that make it more energy expensive, even if one does arrive more quickly. That is, say air drag dominates and is proportional to velocity ^ 2. Then if the power required to move the car at velocity V through the air is P, then the power required to move at twice V is 4P, not 2P. So then even if the car has made the same trip at 2V in half the time, it has expended energy at 4 times the rate to do so. This is also the reason why the energy required to travel at constant speed through a fluid is less than the energy required for the same trip traveling at lower and higher speeds that average the same speed, and similarly hence the effectiveness of the 55mph speed limit in conserving energy.
starkind said:
Hmmm.
This is actually a very interesting question. The answer is of course quite complex and might have several answers.
Given that the kinetic energy of an object is equal to 1/2mv^2, one might assume that the petrol energy required to accelerate a vehicle to speed would be the same for all cases.
I'll simplify the problem by having two vehicles reach their destination at the point the slower accelerating car reaches the target speed of say, 50 mph.
Fast car accelerates at 50mph/60 seconds.
Slow car accelerates at 50mph/60 minutes.
So the slow car travels 25 miles getting to it's target speed and takes an hour to get there.
The fast car takes about 30 minutes to arrive.
In this example, the slow car would have to get twice the fuel mileage than that of the faster car in order to win the mpg race.
Now this is just my opinion, but I think the fast car would win the mpg contest.
The other extreme of course, is the quarter mile dragster, which interestingly, gets about 1/4 mile per gallon. Pitted against the slow car above, it would probably lose the mpg contest.
These are extreme cases, but I think it points out that there may be an optimal acceleration for every vehicle, when considering fuel economy.
FredGarvin said:
One thing I know does help is to use cruise control whenever possible on trips. I experimented with my truck on trips. It does indeed help.
Fred,
All the cruise controls I ever used would try to maintain speed up hills and slow down on the other side to keep the speed constant. If you're trying to save fuel, the best way would be to let the kinetic energy from the downside of hill A help you to travel up hill B. Unless you travel on pretty flat ground. That's OK too.
brewnog said:
Look at Diesel exhaust gas; a very large proportion of that is water vapour. Most of this is a product of combustion, but some is straight from the fuel too. Any hydrogen/oxygen bonds which are broken during combustion are re-made again very, very quickly during the combustion reaction, and still ultimately released as water vapour in the exhaust. Why do you suggest water within the fuel increases fuel economy? Sure, you can inject water into the cylinder to improve efficiency, but this is due to charge cooling effects from evaporation, and not hydrogen/oxygen reaction kinetics.
The better fuel economy of WDE comes from its water component. Water converts heat energy into motive energy. In an ICE (Internal Combustion Engine) it is not heat, a by-product of combustion, that drives the pistons. It is the combustion gases (H2O + CO2) that provide the motive energy. Since one litre of fuel produces more or less one litre of water, a mixture containing 25 percent water and 75 percent diesel, should produce the same volume of combustion gases as that of pure diesel. There should not be any power loss arising from the use of WDE.
What is important is to ensure that the higher viscosity of WDE is addressed i.e. adding a pump to deliver WDE to the engine (to ensure the engine is not starved of fuel), preheating WDE fuel to reduce its viscosity, fuel tank agitation to ensure fuel consistency.
In an ICE (Internal Combustion Engine), it is the volume of combustion gases - CO2, H2O, CO, NOX - that provides the motive energy that drives the pistons.
Since 1 litre of diesel produces approximately 1 litre of water during combustion, the total volume of combustion gases produced by an emulsion of diesel should give the same power as pure diesel even though it contains less diesel.
Another benefit of water diesel emulsion is the effect of secondary atomization of fuel droplets that result in a more complete combustion. More complete combusion means less fuel wastage.
There is absolutely no reason why any ICE should be using pure diesel. Converting waste combustion heat to motive energy should be the way forward.
Waste heat is currently dumped into the atmosphere via the engine's radiator. Such a wasteful use of a scarce resource should be immediately stopped.
It makes me drive badly! I rented a prius recently - I had to keep reminding myself to look at the road instead of the watching the computer as I experimented with what it was doing.
The display is definitely bad. It's not the fuel thing so much but the radio and heat/ac are all touch screen. You could go of the road. But we got 58 mpg on a trip. That's more than a Smartcar.
How do you propose that this waste heat is all recovered and used?
I think at least one of the US Army's tanks powered by gas turbines uses peltier stacks to generate electrical power from the waste heat.
There are two devices that make me utterly crazy in my research on fuel savings: peltier generators and sterling engines. Finding the efficiencies are almost impossible. The wiki entry on sterling engines looks like it was written by someone trying to sell them.
Todays search for peltier stack generators yielded the following:
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JAPIAU000101000002023704000001&idtype=cvips&gifs=yes
The maximum energy conversion efficiency DeltaW/Winput obtained at an optimum period is 0.37% for the generator
Now is it my imagination, or are peltier stacks the least efficient of any device on the planet?
And don't get me started on sterling engines. Ok. Let me. I once read that a 4hp sterling engine weighed 2 tons. (Both these numbers may be off by a factor of two as I cannot find the original reference.)
In an ICE (Internal Combustion Engine), it is the volume of combustion gases - CO2, H2O, CO, NOX - (NOT HEAT) that provides the expansion energy that drives the pistons.
Since 1 litre of diesel produces approximately 1 litre of water during combustion, the total volume of combustion gases produced by an emulsion of diesel (containing say 33.33 percent water and 66.66 percent diesel) should be about the same. It should, therefore, give the same power as pure diesel even though it contains 33.33 percent less diesel.
Waste heat of combustion converts WDE's water component into superheated steam.
Preheating WDE fuel to 60 deg C using an engine's coolant has two benefits. First, it reduces its viscosity for a better fuel spray quality. Second, it minimizes the heat absorption rate of WDE's water component. Since diesel engines rely on the heat of compression for ignition, preheating WDE will minimize its impact on the engine's designed heat of compression.
How can a liter of diesel possibly produce a liter of water when it is combusted? Doesn't any of the carbon in the diesel get combusted to CO2 or CO? How about some references to back up this claim?
A Typical chemical formula of diesel = C12H23. When combusted the C combines with O2 to produce CO2 and the H2 combines with O2 to produce 2 H2O.
H2O = Water
H2O = Water
More precisely, in a pure oxygen atmosphere:
CxHy + (x+y/4)O2 -> xCO2 + (y/2)H2O
so for every mole of C12H23 diesel one would have 12 moles of CO2 and 12.5 moles of water products
I disagree. Work is created from thermal expansion in both the Otto and Diesel cycles, hence why they are called Heat Engines. This can be shown with P-v and T-s diagrams. I will agree with you that work might be obtained from the restructuring of molecules during the reaction, but the majority of the work is created from the heat from the exothermic reaction.
A heat engine typically uses energy provided in the form of heat to do work and then exhausts the heat which cannot be used to do work
http://hyperphysics.phy-astr.gsu.edu/Hbase/thermo/heaeng.html#c3
Recovering this waste heat isn't an easy thing to do. Peltier/thermo-piles and sterling engines look great on paper, however in practice they are just about worthless. Kind of like the Carnot cycle. BMW created some device to recover waste heat from the exhaust and reuse it but I believe it ended up being a pretty big failure. Something about the added weight not being worth the gains in efficiency.
Where did you hear that?
I can find no reference on the net that implies they've stopped their turbosteamer research program.
http://www.bmwgroup.com/e/nav/index.html?http://www.bmwgroup.com/e/0_0_www_bmwgroup_com/forschung_entwicklung/science_club/veroeffentlichte_artikel/2006/news20063.html"
But thanks for reminding me. I see now that they've published their Th & Tc (1000'F & 160'F)
Lets see, that's 810'K and 344'K which yields a Carnot efficiency of 57%.
They claim a 15% increase in efficiency with the system.
hmmm...
Someone correct me if the following assumptions and conclusion are wrong:
ICE's are 25% efficient.
Multiplying 25% x 57% yields ~15%.
Is it safe to assume that BMW has extracted all the practical usable energy using this system? Or is the 15% mathematical result just a coincidence.
Heat alone has no motive energy. A medium such as water is necessary to convert heat energy into motive energy.
Water droplets encased in diesel instantly flashes into steam upon entry into an ICE combustion chamber. This secondary atomization of fuel droplets accelerates the rate of combustion.
Obviously a working medium is required for thermal expansion. If it wasn't, then it wouldn't be called thermal expansion. However this is not what you stated. You stated that the energy that provides the expansion of the medium does NOT come from heat which is a false statement.
OmCheeto, I cann't remember exactly where I heard that nor could I find any info on it either. I believe I heard it from a german engineer from my last job. Also, all articles I could find on it were no later than 2006. There seems to be no info on it from the past couple years. So, its anyones guess what stage the project is at now.
Given that it was a secret project for the first 5 years, I'd say they've gone back into stealth mode. I came up with the same idea independently six months before they announced it. I've been continuously improving my design ever since, and I would imagine they're doing the same. They did say it would be another 10 years before it was to go into production.
Btw, this was the topic of my very first thread here at the forum; https://www.physicsforums.com/showthread.php?t=203654"
I had stated that "it is the volume of combustion gases that drives the piston and not heat. Heat is a by-product of combustion." A Water Diesel Emulsion fuel uses waste heat from the combustion of fuel to convert water into superheated steam. My contention is "Why use pure diesel, when you can get the same performance from a fuel containing only two third fuel and one third water?"
One thing I recommend to people if they don't do a lot of long-hauls, is to not fill up completely when they stop to get gas. One gallon of gas weighs ~6.2lbs, +/- .3lbs depending on the temperature. If you drive a vehicle with a large enough gas tank, the weight can really start to add up.
My DD has a 13 gallon gas tank, but I only pump about 4 or 5 gallons when I stop. Granted I have to stop more often, but I usually stop in gas stations frequently for drinks or a snack anyway. In my case, it's saving the car from having to haul around an extra ~56lbs for no reason. I also ditched my spare tire and factory toolkit since I have a cellphone.
The thing that would likely help me save is having some kind of feedback on the dash that indicated the actual rate of fuel use, maybe even the amount of fuel use on a trip normalized to cost to make it easier to relate to. That way you end up knowing in concrete terms how much the trip to the grogers cost you fuel-wise.
But I don't see paying a lot for something like that.
I think it would help people see the incremental difference in carrying extra weight or passengers, or slowing to a light from farther back and not coming to a complete stop before a light changes, etc. Basically any feedback that raises consciousness in gas usage seems like a good thing and might pay noticeable benefits in fuel use more universally.
Some cars have them and yes, they would be a big help. I've heard people say they can watch the gage and learn how to drive more efficiently.
I'm not a big proponent of making cars more complicated, but it seems that the on board computer that already likely has the necessary access to information like cycles fired, and could additionally get measures of gross pedal detent and self calibrate on learned fuel usage, could with incremental hardware cost and programming be used to provide a fairly accurate instantaneous as well as trip and tank efficiency.
But I think it would need to be integrated by the manufacturer and I can imagine it would be decidedly inaccurate if it was an add-on.
LowlyPion said:
I'm not a big proponent of making cars more complicated.
I am. As long as they can be made to function reliably, complexification is not a bad thing.
Just look at your pc. 30 years ago they were dumber than a modern cell phone. PC's are now more complicated and more reliable. (I drive a macbook. 1 crash in 1 year. It's all about manufacturing quality.)
But I didn't resurrect this thread just to argue with you.
Tah dah!
You can now bid on a 150mpg Toyota Prius plug in hybrid on ebay.
It's actually a charitable auction, with proceeds going to pluginamerica.org
Bidding started at $25k on Halloween and is now at $42.1k
I wasn't sure where to put this post, but I figured if someone wanted to get better fuel savings, just buy a car that gets great mileage.
Trying to eek out an extra 20 to 30% fuel economy in a car that started out at 20mpg is just silly. Which is, um, what I've been doing...:redface:
I don't think so: all cars are required by law to have a standard data port for diagnostics. I have a device that data logs mine (I bought it because it was cool and only use it occasionally). It shouldn't be hard to plug into that and add access to your car's inner workings. Heck, don't street racers do that? I'm pretty sure I saw a guy screwing with his motor via a laptop right before a race on "The Fast and the Furious" (yeah, I did just cite that...).
edit: here's a piece of software for that kind of thing (look at the last pic in the article): http://www.thinkythings.org/obdii/
Here you go: http://www.ecutalk.com/consultlcd.aspx
Not real slick looking, but while I was googling, I saw that GM is going to start making an aftermarket display for this. People are also modding pocket pc's and PSPs for this. I'd love to have such a thing mounted on my dash next to my mp3 player and gps.
LowlyPion said:
I'm not a big proponent of making cars more complicated, but it seems that the on board computer that already likely has the necessary access to information like cycles fired...
This is what many people I know use: http://www.scangauge.com/. I have a BR3 OBD-II scan tool from these guys http://www.obddiagnostics.com but it requires a laptop to use it.
The Scangauge has a calibration step for mileage that you can use to make sure it's accurate; both units can display many engine metrics that are reported through the OBD-II system like RPM, throttle %, air intake temperature, air intake flow, etc. etc.
That's a whole new level, and usually is because the engine has aftermarket components that severely change fuel and air delivery, like aftermarket forced induction.
I have a piggyback fuel/timing calibrator (SplitSecond FTC1-E) on my Toyota 4Runner because I have a supercharger and larger fuel injectors on it. Using a laptop I can tune fuel and timing maps that "trick" the engine's stock ECU into adding more or less fuel, or decreasing timing advance to help get rid of spark knock. Installation of the unit is very involved and requires cutting and/or tapping into wires going to the stock ECU (you have to be sure you want to do it).
Each tuning map is basically a spreadsheet with engine rpm and manifold absolute pressure for columns and rows like this: fuel map example. Using a laptop to program the unit, you can adjust how much fuel is being put into the engine at a specific rpm and manifold pressure.
It's not silly. Increasing a 20mpg car by 20% will save about 8 gallons for every 1000 miles driven. (About one month's worth of driving.)
Increasing a 40 mpg car by 20% has less fuel savings, about 4 gallons per 1000 miles.
