Tetherball - find theta and tension
  • Thread starter Thread starter JJBladester
    Tension Theta
6 replies · 27K views · last reply
JJBladester
A 450-g tetherball A is moving along a horizontal circular path at a constant speed of 4m/s. Determine (a) the angle θ that the cord forms with pole BC, (b) the tension in the cord.
[tex]\sum F_{y}=ma_{y}[/tex]
[tex]\sum F_{n}=ma_{n}=m\frac{v^{2}}{r}[/tex]
Find θ and T.
Given:
m=0.45kg
v=4m/s
FBD:
Sum of forces equations:
(1)[tex]\sum F_{y}=-mg+Tsin\theta =0 \to Tsin\theta =mg[/tex]
(2)[tex]\sum F_{n}=Tcos\theta =m\frac{v^{2}}{r} \to T=m\frac{v^{2}}{rcos\theta}[/tex]
Substitute expression for T found in (2) into (1):
[tex]\left (m\frac{v^{2}}{r} \right )tan\theta =mg[/tex]
[tex]\theta =tan^{-1}\left (\frac{gr}{v^{2}} \right )[/tex]
This is where I get stuck. I know that if I can find r, I can find θ and subsequently T. How do I find r?
You have found that
tanθ = gr/v^2.
Check this expression. In FBD angles indicated are different.
In the problem, the length of cord L is given. So sinθ = r/L.
Put it in the expression and find θ.
I fixed my FBD so that θ is in the correct place:
[tex]sin\theta=\frac{r}{1.8}\rightarrow r=1.8sin\theta[/tex]
[tex]\sum F_{y}=-mg+Tcos\theta=0[/tex]
(1) [tex]Tcos\theta=mg[/tex]
[tex]\sum F_{n}=Tsin\theta=m\frac{v^{2}}{r}[/tex]
(2) [tex]T=\frac{mv^{2}}{rsin\theta}[/tex]
Substituting (2) into (1) yields:
[tex]\left (\frac{mv^2}{rsin\theta} \right )cos\theta=mg[/tex]
[tex]\frac{cos\theta}{sin^2\theta}=\frac{1.8g}{v^2}[/tex]
How do I simplify the [itex]\frac{cos\theta}{sin^2\theta}[/itex] to solve for θ?
Hint: Look up the Pythagorean trig identities. (I'm sure it's one you already know.)
Doc Al said:
Hint: Look up the Pythagorean trig identities...
I did this:
[tex]\frac{cos\theta}{sin^2\theta}=\frac{cos\theta}{1-cos^2\theta}[/tex]
Making the equation:
[tex]\frac{cos\theta}{1-cos^2\theta}=\frac{1.8g}{v^2}[/tex]
However, this doesn't get me any closer to getting theta out on its own.
Sure it does. Hint: Rearrange that equation and solve for cosθ. (You'll get a quadratic.)
Doc Al said:
You'll get a quadratic...
Thanks to both of you for the persistence. With your help, the solution presented itself:
[tex]\left (\frac{1.8g}{v^2} \right )cos\theta+cos\theta-\left (\frac{1.8g}{v^2} \right )=0[/tex]
[tex]cos\theta=\frac{-1+\sqrt{1^2-4\left (\frac{1.8g}{v^2} \right )\left (\frac{-1.8g}{v^2} \right )}}{2\left (\frac{1.8g}{v^2} \right )}[/tex]
[tex]\theta\approx49.9[/tex] degrees
[tex]T=\frac{mg}{cos\theta}=\frac{\left (0.45kg \right )\left (9.81m/s^2 \right )}{cos(49.9)}\approx6.85N[/tex]
These answers line up with the book's answers. Again, thanks to both of you for the help.
