The Bolzano Weirstrass Proof by Construction
  • Context: Graduate
  • Thread starter Thread starter Bachelier
    Construction Proof
8 replies · 3K views
Bachelier
Is this good? thanks
Proof:
let [tex]S[/tex] be an infinite bounded set in [tex]\Re[/tex]
then [tex]\exists[/tex] real numbers a, b such that
[tex]S[/tex] is in [a, b]
One of the intervals, [a, (a+b)/2] or [(a+b)/2, b] contains an infinite set of members of S. Let's choose one with this property and call it [tex][a_1, b_1][/tex]
Continuing in this fashion we obtain for each positive integer n the closed interval [tex][a_n, b_n][/tex] with the following properties:
1. [tex]d(a_n, b_n) \leq |a-b|/2^n[/tex]
2. [tex][a_n, b_n][/tex] contains infinitely many points
3. and [tex][a_n, b_n] \subset [a, b][/tex]​
so [tex][a_n, b_n][/tex] is bounded. let [tex]P= \{a_n|n \in\mathbb{N} \}[/tex]
So P is bounded. let x= sup P
Surely the sequence [tex]a_n[/tex] is increasing.
Claim: [tex]a_n[/tex] converges to x
now [tex]\forall \epsilon > 0 \ \exists N \in \mathbb{N}[/tex] with [tex]N > |a-b|/2^n \ \forall \ n>N[/tex]
then [tex]|a_n - x| \leq |a-b|/2^n < |a-b|/2^N< |a-b|/N = \epsilon[/tex]
If you are proving that each bounded sequence has a convergent subsequence, you must also deal with the case that the bounded sequence takes on only a finite number of values.
Isn't it that in that case just select one of those finite values and thenceforth you have a convergent subsequence?
Yes
The sequence is nondecreasing if that's how you define "increasing".
let [tex]P= \{a_n \ | \ n \in {N} \}[/tex]
What is [tex]{N}[/tex]?
You conclude by claiming that an arbitrary epsilon is equal to |a-b| divided by an integer, which can't be right.
Sorry that was [tex]\mathbb{N}[/tex]
My browser was playing tricks with my code.
Actually I found a large enough natural number N such that the distance from an to sup(P) is less than [tex]\epsilon \ (\forall \epsilon > 0)[/tex]
The question is, do I have to include the bns as well?
That makes no sense to me. What statement is the "if" that goes before the "then"?
Are you saying that the last relation should be [tex]\leq \epsilon[/tex] instead of = [tex]\epsilon[/tex] ?
(And do you find the way LaTex shows up on the forum to be buggy? I admit that I'm out of practice with LaTex, but I can cut and paste things other people have written and it doesn't show up correctly. Sometimes what shows up are symbols from parts of posts that I haven't even pasted. I've tried both the Opera and Firefox browsers.
Edit: The problem is discussed in this post: https://www.physicsforums.com/showthread.php?t=482096 )
OK, take a look at this:
[tex]\forall \epsilon > 0 \ , \ (\exists N \in \mathbb{N}) \ with \ [N > |a-b|/\epsilon] \ such \ that \ \forall \ n>N \ \mbox{implies that}[/tex]
[tex]|a_n - x| \leq |a-b|/2^n < |a-b|/2^N \ \mbox{(because N is strictly less than n so 1/2^n < 1/2^N) \ (note: \ 2^N > N)}[/tex]
[tex]Hence |a_n - x| < |a-b|/N = \epsilon \ \mbox{after replacing N}[/tex]
[tex]should \ have \ divided \ by \ \epsilon \ in \ my \ original \ post. \[/tex]
