The Density of a Nucleus: A Question About Steps in Calculating Nuclear Density
  • Thread starter Thread starter nmsurobert
    Density Nucleus
The discussion centers on the calculation of nuclear density using the formula ρn = mn/Vn, where mn is approximately equal to ma. The participant identifies a potential error in the solution regarding the volume calculation, suggesting that the radius should be cubed, leading to the correct expression ρn = ρa/(10^-5)^3. This adjustment is crucial for accurate density calculations, as failing to cube the radius results in an incorrect density value of 108 kg/m³ instead of the expected result.
  • Understanding of nuclear physics concepts, specifically nuclear density calculations.
  • Familiarity with the formula for density (ρ = mass/volume).
  • Knowledge of the significance of cubing in volume calculations related to spherical objects.
  • Basic mathematical skills for manipulating scientific notation.
  • Review the principles of nuclear density and its calculation methods.
  • Study the implications of dimensional analysis in physics problems.
  • Learn about the significance of volume in relation to radius in spherical objects.
  • Explore additional examples of density calculations in nuclear physics.
Students and educators in physics, particularly those focusing on nuclear physics, as well as anyone involved in scientific calculations requiring precision in density measurements.
nmsurobert
There is relatively little empty space between atoms in solids and liquids, so that the average density of an atom is about the same as matter on a macroscopic scale—approximately 10^3 kg/m^3 . The nucleus of an atom has a radius about 10^-5 that of the atom and contains nearly all the mass of the entire atom. (a) What is the approximate density of a nucleus?
ρ = m/V
I have the solution to the problem but I think I found either a typo or steps that were not included. I think I have made sense of the problem but I would like to double check that I'm doing this right. Thanks.
ρn = mn/Vn
mn ≈ ma
Rn = 10-5Ra
This is were I am having issue. The solution says:
ρn = ma/10-5Va = ρa/10-5
ρn = 103 kg/m3/10-5
It says 10-5Va. Shouldn't it be (10-5)3Va because of the radius is a cubed value? Same for the ρn/10-5. Shouldn't it also be ρa/(10-5)3?
If those values are not cubed then I end up with
ρn = 103 kg/m3/10-5 = 108... which is not right.
But if I cube that value then I get the correct answer. I wrote up a similar problem using simpler numbers and my logic checked out. However, like I said, I just wanted to double check.
You are correct. They should have cubed the 10-5.
awesome. thanks.
  • · Replies 17 ·
