The electron as a wave: what is it that waves
The discussion centers on the nature of electrons as waves in quantum mechanics, specifically addressing the distinction between electromagnetic waves and the probability waves associated with electrons. The lecturer clarified that when an electron behaves as a wave, it is described by its wave function, which represents the probability amplitude rather than an electromagnetic field. The conversation also touches on the concept of quantum phase and its role in phenomena like the double-slit experiment, emphasizing that the electron field is distinct from the electromagnetic field.
  • Understanding of quantum mechanics principles
  • Familiarity with wave functions and probability amplitudes
  • Knowledge of the double-slit experiment and wave-particle duality
  • Basic concepts of fermion and boson fields
  • Study the mathematical formulation of wave functions in quantum mechanics
  • Explore the implications of quantum phase in wave-particle duality
  • Investigate the differences between fermion and boson fields
  • Examine experimental evidence of electron wave behavior, such as interference patterns
Students of physics, particularly those studying quantum mechanics, educators explaining wave-particle duality, and researchers interested in the foundational aspects of quantum theory.
carwe
The electron as a wave: what is it that "waves"
When taking a course in Modern Physics, after doing quite a lot of thinking, I finally asked the lecturer: when the elctron behaves as a wave, what kind of wave does it behave as? Does it behave as an electromagnetic wave? The answer was no. I thought for a second an asked, "Is it the probability that waves"? The lecturer thought for some moments and then aswered "yes".
Or, in other words, my question is: what does the oscillating variable describe? For an em wave it is obvious, it is the magnitude of the electric or magnetic field. So, when describing the electron as a wave, is it still so?
No, acording to the lecturer, which makes sense; we e.g. calculated the wave function for an electron-in-a-box, clearly; the wave appears and it is apparently the probability that "waves".
...but, in that case: when an em wave behaves as a particle, a photon, can that photon also be described as a "probability wave", different from the em wave?
Can someone give me some hints on this? I might very well be messing up a lot of things...
Thanks.
No, to be precise. It's the quantum phase that waves (the thing that is responsible for the double-slit pattern). The probability is the squared amplitude of that wave, but it is possible for it to be constant, so the probability is not "waving", while the phase still does.
The only thing that comes to mind with "waving probability" is the superposition of particles with different masses, i.e. neutrinos or neutral kaon.
It's nothing but the electron field. Not the electromagnetic field, but the electron field. Note that fermion fields are a bit different from boson fields.
No, it can't, which is a flaw in QM, IMO.
What "waves" is really the mathematical construction of the quantum state. Take a particle in a box as an example; by solving the stationary S.E you get wave functions that are superpositions of two waves traveling in opposite directions. Of course, the physical interpretation of the solutions are found by taking the absolute square of the wave functions - the "waves" are left as mathematical building blocks.
In some experiments the electron behaves like a wave:
1) http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/davger2.html#c1"
You shoot electrons at a crystal and observe an interference pattern. The pattern can be explained if you assume that the electron has a wavelength.
2) http://www.perimeterinstitute.ca/Perimeter_Explorations/Quantum_Reality/Chapter_2_-_Wave-Particle_Duality_with_Electrons/"
(Chapter 2, Perimeter Institute for Theoretical Physics)
You observe dots on the screen but the pattern looks as if produced by wave interference.
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 26 ·
