The Foundations of a Non-Naive Mathematics
The discussion revolves around the foundational concepts of a proposed non-naive mathematical framework, as presented by the original poster. It includes definitions of mathematical objects such as sets, multisets, and axioms that govern their relationships and properties. The scope encompasses theoretical exploration of mathematical structures and their implications.
  • The original poster introduces a set of axioms defining concepts such as tautology, sets, multisets, and urelements, emphasizing their foundational roles in the proposed framework.
  • Some participants discuss the duality concept, suggesting that each element of the Real-Line possesses both local and global properties.
  • There is a claim that a point can only be defined using equality, while a segment can be defined using inequalities or equality, indicating a distinction between these two building blocks.
  • Participants explore the implications of the axioms of independence, complementarity, and minimal structure on the understanding of mathematical objects.
  • Some participants propose that the Real-Line exhibits properties of both absolute and relative systems, influenced by the definitions of points and segments.
  • There are references to graphical models and diagrams that are suggested as aids for understanding the proposed concepts.
Participants express various interpretations of the axioms and concepts, indicating that multiple competing views remain. The discussion does not reach a consensus on the definitions or implications of the proposed framework.
The discussion includes complex definitions and relationships that may depend on specific interpretations of terms such as "tautology," "set," and "urelement." Some mathematical steps and assumptions are not fully resolved, leaving room for further exploration.
  • #451
So, you've got something that is your version of R, though you've not shown that it is a field, that it has a metric (though you've used it, preversely), that it is complete, etc... of course I understand that this is not necessary because your R is not the R as understood by the rest of humanity, just as those aren't naturals as we know them, tautology has a new meaning, as does =, symmetry you use without explanation, and I'm very impressed that you've introduced another spurious and unexplained property (tight). also, you're presuming that your set R has a direction given by an order, something else you've not shown to be true, nor that there is anything in those intervals, or that pi even exists in that system as a deducible fact from the axioms.
your axioms are rather clever in that part of them is that anything you choose to exist exists without proof.
  • #452
arildno and CrankFan,
No matter how many times you will look at my work from your spot of reasoning, you will not be able to understand it, unless you come to my spot.
If you do not want to do it or cannot do it, then do not west your time in this thread, because you will see nothing, even after 20 years.
  • #453
Please explain what a "spot of reasoning" is.
And, mind you, no silly analogies this time.
  • #454
Yes Matt isn't it beautiful and simple?
1) A thing is always consistent with itself, otherwise we cannot find it.
2) Since we can find it we do not need to prove its existence.
3) Now all we need is to find interesting and useful ways of interactions between our tautologies.
4) The definitions of our used concepts help us to construct some agreement that can help us to work together, but we have to be aware that this common agreement is only a tool for the mathematical creation itself, which is always a unique creation of the person which creates it, and it is never a technical tuning of the agreement.
The mathematical unique creation changes the agreement, because it is an open thing by nature, where any agreement is a closed thing by nature that has to fit itself to Math development when time comes.
During the last 2500 years we can see that meaningful developments in Math always changed the common agreement, where persons that had no creative minds where forced to change their common agreements in order to fit themselves to the new development.
And why they where forced to do it?
Because this development was not their creation, and this creation broke their agreement, which is the only playground for non-creative persons.
Edit:
I want to add some notes about '=' notation which is in my system is first of all used for tautology, where tautology in my system is the identity of a thing to itself.
But I also continue to use this symbol in the standard way for example:
4=2+2 but this equation is different then 4=4 and 2+2=2+2 which are tautologies
(for eample:
4=0_______4 ; 2=0___2 ; 2+2=0___2 + 0___2 ).
By 4=2+2 we clearly mean that we care only about the quantity,
because it is clearly understood that (0_______4) is not (0___2 + 0___2) by tautology.
Actually we use quantity as a "glue" to connect different tautologies to each other, for example:
For example, let us represent the variations of cardinals(*) 2,3,4:
Let Redundancy be more then one copy of the same value can be found.
Let Uncertainty be more than one unique value can be found.
Let XOR be #
Let a=0,b=1,c=2,d=3 then we get:
Code:
    b  b
   {a, a,  {a, b}
    |__|_   |__|
    {x,x}  {{x},x}
     c  c  c
     b  b  b          b  b
    {a, a, a,}       {a, a, c}       {a, b, b}
     |  |  |          |__|_ |         |__|_ |
     |__|__|_         |_____|         |_____|
    {{x,x,x}         {{x,x},x}       {{x},x},x}
                [B]Uncertainty[/B]
  <-[B]Redundancy[/B]->^
    d  d  d  d  |
    c  c  c  c  |
    b  b  b  b  |
   {a, a, a, a} V   {a, b, c, d}
    |  |  |  |       |__|  |  |
    |  |  |  |       |     |  | <--(Standard Math language uses only
    |  |  |  |       |_____|  |     this no-redundancy_
    |  |  |  |       |        |     no-uncertainty_symmetry)
    |__|__|__|_      |________|
    ={x,x,x,x}       ={{{{x},x},x},x}
                [B]Uncertainty[/B]
    d  d  d  d  |          d  d             d  d
    c  c  c  c  |          c  c             c  c
    b  b  b  b  |    b  b  b  b             b  b       b  b  b  b
   {a, a, a, a} V   {a, a, a, a}     {a, b, a, a}     {a, a, a, a}
    |  |  |  |       |__|_ |  |       |__|  |  |       |__|_ |__|_
    |__|__|__|_      |_____|__|_      |_____|__|_      |_____|____
    {x,x,x,x}        {{x,x},x,x}      {{{x},x},x,x}    {{x,x},{x,x}}
                                      c  c  c
          b  b                        b  b  b          b  b
   {a, b, a, a}     {a, b, a, b}     {a, a, a, d}     {a, a, c, d}
    |__|  |__|_      |__|  |__|       |  |  |  |       |__|_ |  |
    |     |          |     |          |__|__|_ |       |_____|  |
    |_____|____      |_____|____      |________|       |________|
    {{{x},x},{x,x}} {{{x},x},{{x},x}} {{x,x,x},x}      {{{x,x},x},x}
    a, b, c, d}
    |__|  |  |
    |     |  | <--(Standard Math language uses only this
    |_____|  |     no-redundancy_no-uncertainty_symmetry)
    |________|
    {{{{x},x},x},x}
  • #455
Lama,
What makes you so certain that you aren't the one who is misunderstanding?
Why are you so insistent that all of the people who have criticized your presentation for being ambiguous aren't fully grasping it, and need to see a repost of one of your papers? Maybe it's the other way around, maybe you aren't entirely grasping the nature of their criticism. Maybe you need to work harder to understand criticism of your work and stop automatically dismissing it.
If you are sincerely interested in communicating your ideas to people in this forum then I think the best approach for you is to find some rigorous mathematics texts on a subject you think you would enjoy and then study those texts in earnest. Follow all of the proofs, do all of the exercises, suppress your ego and seek help from people when you are genuinely stuck. Be sincere in your approach to learn and understand it.
If you do this, you will learn by example (of the author) and through practice (completing the exercises) what is roughly considered to be an acceptable definition and proof. Then, you can utilize this knowledge to describe your ideas so that they can be understood by your target audience on this forum.
  • #456
Please understand that you did not show any understading of my work.
On the contrary I showed that understand the standard framework.
  • #457
Lama, I think you would have more success creating a new religious belief than a new system of math. You skillsets would serve you better in that endeavor.
  • #458
Eeh, whenever you've been pinned down to specifics (for example, in your usage of "tautology" or "="), you have consistently shown a lack of understanding of these terms; you have been using them with completely different meanings than standard usage
  • #459
arildno said:
you have been using them with completely different meanings than standard usage.
Yes, you are right because my framework is based on an included-middle reasoning.
Do you say it after you showed us that you understand what is an included-middle reasoning?
  • #460
Please explain what included-middle reasoning is, and why it is valid to term it a "reasoning"
  • #461
Each one of us can understand the other by using its logical reasoning method.
You use the excluded-middle reasoning and I use an included-middle reasoning, which is deeper, simpler and richer then the excluded-middle reasoning.
In short, excluded-middle reasoning is nothing but a trivial sub-system of included-middle reasoning, and included-middle reasoning cannot be understood from this "spot of reasoning".
  • #462
You are an arrogant idiot. Goodbye
  • #463
Please read http://www.geocities.com/complementarytheory/No-Naive-Math.pdf and see for yourself not just what is an included-middle reasoning, but how I use it to develop my framework.
Why, is it because of something that you have found in my article?
  • #464
Lama, please try to understand that this is not a valid response to the question you were asked. You have simply made grandiose statements that your reasoning is so much better than the one we've been using for 200 years, but failed to offer a single statement in support of that. Show how it can be "simpler, richer and deeper" than what we have. Show how the excluded middle reasoning is a trivial subsystem of it (which I think is not true as the two systems are contradictory. Feel free to correct me if you can convincingly show otherwise). I don't know whether you realize that absolutely everyone here says simiar things about their pet theories, and such claims always have the opposite effect of what they intend. You may also not realize that people don't like being constantly given reading assignments, since it is your job to make your case through reasonably self-contained posts. You may not be aware that in some forums, this practice is considered spam and such posts are summarily erased.
Call me a bodyguard too if you like, as you've expressed your dislike of my methods before. It is ironic that for one who is having such a hard time making himself understood (which you seem to genuinely want), you have not even tried to understand the method to my madness. As mathematics is not subject to the constraint of having to describe an experimentally accessible world, your system can coexist with any other system, assuming of course it is consistent, satisfies the standards of rigor, and it is useful in that it allows desirable results to be drawn. I am not a mathematician so I am not qualified to judge that, hence I do not want you to waste your time on me. Feel free to put my advice to whatever use you wish.
  • #465
What does included middle reasoning have to do with you changing the definition of tautology?
ex-xian said:
If "finite" has it's standard mathematical meaning, then you are assuming the existence of the natural numbers. Here's Rudin's definition of a finite set
Lama said:
I already gave you my answer to 'finite', which is:
The axiom of completeness:
A collection is complete if an only if both lowest and highest bounds are included in it and it has a finite quantity of scale levels.
This is circular reasoning! I asked to define finite w/o "standard" mathematics or else concede everything I specified above. You respond by "answering" finite with an axiom that includes the disputed definition.
This is really getting silly.
  • #466
Dear anti-crank,
What I was doing in the last 2 years in this forum is to develop my framework by trying the best I can to explain my non-standard ideas.
Instead of look around you and see what other people are saying, I suggesting you to read by yourself the fruits of my efforts.
You do not need complecated mathematical teachings to understand my work because my work is on the most fundamental concepts of the language of mathematics, and because it is new in cannot be compared with the goals and achievements of the standard framework.
Please read:
http://www.geocities.com/complementarytheory/No-Naive-Math.pdf and all of it links,
and also http://www.geocities.com/complementarytheory/My-first-axioms.pdf.
More general view of my work can be found in:
http://www.geocities.com/complementarytheory/CATpage.html
After you have your personal opinion on my work, I'll be glad to discuss with you about it.
Yours,
Lama
  • #467
Then you missed the good part of this post where I wrote:
Lama said:
Then you asked me what is lowest and highest bounds, and my answer is:
The ends of some given element, where beyond them it cannot be found.
This last definition (and its opposite) is for {},{.},{._.} and {__} sets.
As you see I have two basic states for finite things:
One is for singletons like {},{.},{._.} and {__} sets and the other is for collections of {.}_AND_{._.} elements.
If each {.}_AND_{._.} has a unique notation (for example: '1', 'pi' , (1/3=@) '@', (.99999...=&) '&', ...), then a collection with more the one notation can have finite or infinitely many notations, and we do not need ZF axioms for this.
Also please pay attention that Cantor's second diagonal proof does not hold here because we are using a single and unique notation for any given number.
  • #468
But you still have never given a definition for what finite is.
  • #469
Dear ex-xian, please show why do we need a special definition for 'finite'
by demonstrate how we can understand 'finite' in more than one way, thank you.
Anyway I can use this:
a) A colloction of more then one element where its lowest bound and its highest bound are included in it.
b) Lowest bound and highest bound are the ends of some given element (or a collection of more than one element), where beyond them it cannot be found.
  • #470
Ok, but what are the "ends of some given element?" What does "beyond them" mean? As Matt pointed out, you're assigned order to sets without specifying what dicates that order.
  • #471
Instead of repeating Matt's point of view, all you have to do is to read my papers, and then you will discover that my elements ({} and {__} are excluded) are {.}_AND_{._.}, where {.}_AND_{._.} are at least Multiset_AND_Set which is ordered by its own internal symmetry degrees, when a given quantity remains unchanged.
But if we return to standard Math where we have Set_XOR_Multiset (and any fundamental concept is based only on quantity), then in the case of a multiset {1,1,1,1,1} for example, we cannot order its content, but even in this case, it has ends that beyond them it cannot be found.
For example: its lowest bound is '{1,' and its highest bound is ',1}’.
In the case of a "normal" set, where any member is a unique member, the lowest bound is '{x1,' and the highest bound is ',xn}' and we don't care about the internal order of the set, so as you see in both cases the standard point of view remains the same, which means, we care only about the cardinality of some set or multiset contents, and we do not care about their order.
So as you see we can use:
1) Peano axioms of the natural numbers (where a definition of a set does not exist).
2) then we can use the definition of a set as:
Set:
A set is a collection of objects in which order has no significance, and multiplicity is also ignored.
3) And then we can use:
“For any positive integer (natural number) n, let J_n be the set whose elements are the integers 1, 2, ..., n; let J be the set consisting of all positive integers (or natural numbers)...A is finite if A has the same cardinality of J_n for some n” (and this is an example that clearly shows that 'finite' in standard Math is based only on 'quantity').
Let us check again my definition for 'finite':
a) A singleton or a collection of more then one element where its lowest bound and its highest bound are included in it.
b)
As you see my definition is stronger, simpler and richer then the quantity-only definition, because it works for both quantity and structure.
We can do this endless game of questions also to:
1. The empty set is a set as is every member of a set.
(What is: empty, set, every, member?)[/color]
2. If X is a set and, for each x in X, P(x) is a proposition, then
{x in X: P(x)} is a set.
(What is: set, proposition?)
3. If X is a set and Y is a set, so is {X, Y}.
(What is: set?)
4. If X is a set, {z: z in x for some x in X} is a set.
This set the “union of X”.
(What is: set, union?)
5. If X is a nonempty set, {z: zin x for each x in X} is a set.
This set is the “intersection of X”
(What is: set, nonempty, intersection?)
6. If X is a set, {z: z is a subset of X} is a set.
This set is called the power set of X.
(What is: subset?)
7. The set N of all natural numbers is a set.
(What is: set?)
8. No set is a member of itself.
(What is: set, member, itself?)
And in a very short time we get questions like:
What is a definition?
What is What is?
And so on ...
So, as you see ex-xian, any agreement is always based on some arbitrary decision between some community of people that stop the game of endless questions end start to work with each other on the basis of this agreement.
And the Community of Mathematician is not a special community.
  • #472
But this is rubbish. [0,1] is a set with an infinite cardinality (using the words properly, and we cannot use your definitions because they make no sense), that "contains its end points". And this would only be something that applies to sets that have "ends" which is stupid. (the collection of all isomorphism classes of groups of order 6 is finite, but doesn't have any bounds)
  • #473
Ho, yes they have, you cannot find the 7 of them and you cannot find 0 of them, but you can find 1 to 6 of them.
Only if there are also infinitely many scales.
Please read post #471, thank you.
Also you missed this so I copeid it for you:
(for eample:
Actually we use quantity as a "glue" to connect different tautologies to each other.
Let XOR be #
Code:
    b  b
   {a, a,  {a, b}
    |__|_   |__|
    {x,x}  {{x},x}
     c  c  c
     b  b  b          b  b
     |  |  |          |__|_ |         |__|_ |
                [B]Uncertainty[/B]
    d  d  d  d  |
    c  c  c  c  |
    b  b  b  b  |
    |  |  |  |       |__|  |  |
                [B]Uncertainty[/B]
    d  d  d  d  |          d  d             d  d
    c  c  c  c  |          c  c             c  c
                                      c  c  c
          b  b                        b  b  b          b  b
    |     |          |     |          |__|__|_ |       |_____|  |
    a, b, c, d}
    |__|  |  |
    |________|
    {{{{x},x},x},x}
(*) Please pay attention that we are not talking about the natural numbers 2,3,4 but the cardinals 2,3,4.
It means that our Organic Natural Numbers are actually a general representation of information-trees, where any finite quantity of names of R members can be described by them, for example:
Instead of a=0,b=1,c=2,d=3 we can use a=0,b=.5,c=3,d=pi and then we use the same information-trees above.
  • #474
More demonstrations of ignorance? wow you're good.
there are exactly TWO isomorphim classes of groups of order 6, now which of them is the lowest bound and which is the highest bound? it is a finite set after all, so it must have them in your logic.
the rest as i think ex-xian said is spamming. you've no need to repost it, it is "vandalism" to do so in some people's opinions.
  • #475
Matt,
Pease read my posts, because I do not see any detailed comments of you on posts #471 and #473.
Matt Grime said:
there are exactly TWO...
So, it is 2 instead of 6, but it does not matter because both of these cardinals are finite cardinals, and in this case you say bye,bye in 0 and 3.
  • #476
You have absolutely no idea what Matt Grime is talking about, do you?
You asserted that any finite set must contain upper and lower bounds as part of your definition of "finite". Matt gave an example in which the members of the set are not linearly ordered and so your statement makes no sense for that set.
And please stop responding to every criticism with "read all of ...". The fact that someone points out that your second sentence is nonsense doesn't mean that he hasn't already waded through the whole thing.
You are correct that "You do not need complecated mathematical teachings to understand my work". What we need are actual definitions not hand waving and vague examples of things that seem to you to illustrate an idea.
  • #477
But the set of iso classes isn't a set of numbers, so it has no ordering in it, it has no way of describing an upper or lower limit of the elements in it. The set is a collection of things, is it finite? You're confunsing a set and its cardinality. The bounds you gave are the least integer strictly greater than the cardinality of the set in question, and the greatest integer strictly less than ... They bound the cardinality, but in no way form a bound for the set which is what your definition requires.
  • #478
Matt and HallsofIvy,
In my system there is no such thing like lower and upper bounds.
In my system I use the terms lowest and highest bounds, which are totally different things.
Since you do not really read my posts in order to understan them, I don't no how we can communicate with each other.
  • #479
ok, rewrite my post in your head with lowest and highest then. the question still makes sense and the answer doesn't.
the point is quite simple, the only sets you can talk about being finite are those with highest and lowest bounds by your own admission, so this cannot be applied to any set other than something with an ordering and even that makes little sense since i an produce infinite (in the proper sense) sets with highest and lowest memebers
  • #480
b)
And there is nothing here, which is connected to order!
This is a part of post #471, and if you don't read it, as I can clearly understand from what is written in your last post, then you keep talking to yourself.
  • · Replies 64 ·
  • · Replies 26 ·
