The Foundations of a Non-Naive Mathematics
514 replies · 58K views
it doesn't even work for quantity. consider the set underlying the ordinal w+1, then it more than one element in it, and contains a least element and a greatest element, hence ordinals are not allowable in your system, unless you're going to claim w+1 is a finite ordinal?
"Lowest bound and highest bound are the ends of some given element (or a collection of more than one element), where beyond them it cannot be found"
what on Earth is "it" in that sentence referring to? there must be some order on something otherwise you cannot talk of highest or lowest, so what is ordered?
There are two kinds of ordinals in my system, internal and external.
The external ordinals are any change in the quantity of {.}_AND_{._.}.
The internal ordinals are any change in the symmetrical degrees of {.}_AND_{.}, where the cardinality of {.}_AND_{._.} is unchanged.
By 'lowest' and 'highest' I mean lowest existence and highest existence of some element, and there is no connection to order here.
you#ve just redefined ordinal then.
"lowest existence" what does that mean? please give me some example where you may talk of things being lowest and highest which is not from some order?
Take for example the multiset {1,1,1,1,1}.
It cannot be ordered but cardinals 0 and 6 are the lowest and highest bounds of it (I already gave this example in post #471).
Also the notations '{' and '}' are also the bounds of existence of any concept that we research, isn't it?
what has this post to do with anything? why is 6 a bound of the set? it is a bound for that set which allows repeated elements, but? that is not what your axiom for "finiteness"states, since it requires that the "end" elements are in the set for it tobe finite. what is the first and last element of a set without an order on the elements in it?
psot 482, the question about what the"it" refers to in your axiom is still unanswered
Beyond your end you cannot be found anymore, isn't it?
To what "it" do you mean exactly?
I do not care about the internal order of the given set, its end is always determinated by its cardinality.
this is your axiom, so what does the "it" refer to? it's your sentence, presumably you know what the pronoun references.
"I do not care about the internal order of the given set, its end is always determinated by its cardinality"
that is also wrong trivially. {2} and {3} both have cardinality 1, the "end" is not determined by the cardinality. you're confusing a set and its cardinality again.
Yes you are right, therefore the values beyond their ends are cardinals 0 and 2.
It is an element or a collection .
I think that I made a mistake in my previous posts:
The cardinals are not just the ends of a given finite set, but they are also the values that beyond its ends.
I am really Sorry about the confusion.
Here it is again my definition of 'finite' to clarify this mistake:
a) A singleton or a collection of more then one element where its lowest bound and its highest bound are included in it.
b) Lowest bound and highest bound are the ends of some given element (or a collection of more than one element), where beyond them it cannot be found.
I give up...
You're a really sad person. You've spent 20 years at this?! I've tried being patient, asking specific questions, but you are clearly too ignorant of what mathematics really is to be able to answer them.
Now, of course, you're going to rationalize this post by called me a bodyguard of mathematics, telling me that I won't come to where you're standing to look at your point of view, or make ludicrous mystical comments. Of course you're free to do this, but none of that will change the fact that you don't know math and that you're theories are just the ramblings of another (unoriginal) crank.
Have fun trying to be original and deluding yourself. Have fun not answering questions and chaning the subject when you can no longer avoid the major and damning problems that are pointed out in your "theories" (and I use that term very loosely).
My last suggestion to you: actually learn some mathematics. Even if you don't believe it when you're learning it, you'll see how it works and be in a better place to critique it. When people see that you actually understand what you are trying to change, you a lot less likely to be laughed at. As things stand now, you theories are just that...laughable at best. And tragic (that you actually think that qualify as intellectual, scholarly work) at worst.
Let us clarify the 'finite' concept in my framework:
In my system I have 4 building-blocks, which are:
{}, {.}, {._.}, {__}
The cardinal of {} is 0.
The cardinal of {.} is one of many.
The cardinal of {._.} is one of many.
The cardinal of {__} is The one.
The bounds of lowest and highest existence (the ends) of these building-blocks
are determined by their cardinality, for example:
(in this example I omitted {.}_AND_{._.} and used only their building-blocks)
The lowest and highest bounds of {.} are cardinals 1 to 1.
The lowest and highest bounds of {._.} are cardinals 1 to 1.
The lowest and highest bounds of {} are cardinals 0 to 0.
The lowest and highest bounds of {__} are cardinals The 1 to The 1.
The lowest and highest bounds of {{.},{._.},{.}} are cardinals 1 to 3.
The cardinals beyond {.} are 0, n>1 and the 1.
The cardinals beyond {._.} are 0, n>1 and the 1.
The cardinals beyond {} are n>0 and The 1.
The cardinals beyond {___} are any cardinal which is not The 1.
The cardinals beyond some n are 0 and any j where j>n.
Lama said:
Dear ex-xian,
Do you say that after you read
https://www.physicsforums.com/showpost.php?p=282481&postcount=471 ?
Also please read my previous post (#492), thank you.
Oh yes, I read it. I just reenforced my belief that you aren't interested in learning actual math or listening to critiques of your lame, pointless, and ignorant theories. Naturally, you're going to see this as a victory for yourself and the profoundly stupid ideas you write about. Please be assured that this is not the case--I'm not giving up because you've put me in my place. Rather because talking to you is like talking to a child. You can't/won't comprehend what other people write when they don't agree with you. Instead of appempting to receive criticism (which you asked for), you accuse others of being bodyguards of math, refusing to come to where you are, or other ridiculous and childish excuses.
You're either a troll or a pitiful, ignorant individual.
ex-xian said:
...because talking to you is like talking to a child.
Ho dear ex-xian, this is the best complement that I can get, and I which to be opened like a child for the rest of my life.
Now, did read also post #492 ?
Russell E. Rierson said:
contradiction = not-contradiction
How's this for a contradiction. Do you understand my reasoning Lama ?
So ( A = (Set = (2*A))) = Triangle inequality theorem = Triangle inequality theorem = contradiction
The full theory that uses this iiis...
(A = ( Set = ( 2 * A ))) = ( Set = ( 2 * A)) = Three right angles I'm thinking.
If I hadn't posted here before, I wouldn't have seen this.
In that case, let me explain. I did not me "like a child" in the sense of a child's sense of wonder, amazement, and openness. On the contrary, I meant a bratty, stubborn child who clings to what he wants in spite of the adults' explanations. I hope that's more clear.
I've read all your gibberish, yes.
So that's why you lobotomized yourself 20 years ago?
You read but did not understand a single note of it, because you are not able to grasp that mathematics is not just an external method that can be learned in school, but first of all the creative abilities of parsons who can see beyond any given external method, which is based on some agreement between a group of people.
I do not belong to your school of thought, but I clearly showed that I understand the fundamental concepts of your school of thought.
On the contrary I did not show any ability to see things beyond your school of thought, because in your school of thought, you do not learn how to use your creative abilities, but only how to be a good technician of the academic standard system.
But I believe that you can do much more then that, if you reduce your aggressive attitude to unfamiliar ways of thinking, which are not belong to your school of thought.
Lama said:
I do not belong to your school of thought..
You do not belong to any school of thought, because you lack the ability to think (i.e, what is usually considered the defining feature of a human being)
Dear arildno, so why do you waste your time in a thread of someone who cannot think?
On the contrary I learn How to develop my system because of your questions,
and I really want to thank you for that.
What are you smoking and where can I get some?
No, you didn't. Amazing how you post such blatant lies. You displayed your ignorance of even the most simple definitions, of the most basic concepts. When challenged, you asked that we no longer discuss standard math and instead focus on your theories. Here's a hint about mathematics--you can't learn it just from widipedia and mathworld.
Tell you what. See if you can answer these questions about "standard" mathematics.
With a delta-epsilon proof, show that [tex]\lim_{x\rightarrow 2} (x^2+x-6) = 0[/tex].
Find [tex]\frac{d}{dx} (x^2+x-6)[/tex] by first principles.
Prove that [tex]\mathbb{Z}_6[/tex] is an abelian group with respect addition.
Solve this integral, [tex]\int xe^{-x} \,dx[/tex]
If you can do these, then you will have demonstrated a very basic understanding of mathematics. Also, provide detailed explanations of your solutions.
Well, you're typo is actually correct. Other than that, more self-rationalizing. Sad really. Also, the fact that you consider mathematics nothing more than techniques that you think to be successful at mathematics one does not need creativity shows that really haven't studied math at all. Spend some time proving things about and studying the hilbert space [tex]\l^2[/tex] and tell me no creativity is involved.
If I had "aggressive" attitudes toward unfamiliar areas of thought, I wouldn't study mathematics, physics, philosophy, or anything interesting. The point is to explore unfamiliar things that are coherent, not gibberish. Yours is the latter, not the former.
ex-xian said:
With a delta-epsilon proof, show that...
I see that you forgot about:
kaiser:
off course I agree with this definition. I meant for you to provide the definition for the limit of S(n), no need delta epsilon at this point. A limit can be defined using epsilon and S(n). At any case, I am not interested in your definitions at the moment. I need to be convinced that you understand and know how to use the fundamental "conventional" mathematical definitions before we can move on to your definitions.
Lama:
Ok, the main persons in modern Math that are related to the so called rigorous definition of the limit concept are Cauchy and Weierstrass.
Cauchy said:" When some sequence of values that are related one after the other to the same variable, are approaching to some constant, in such a way that they will be distinguished from this constant in any arbitrary smaller sizes that are chosen by us, then we can say that this constant is the limit of these infinitely many values that approaching to it."
Weierstrass took this informal definition and gave this rigorous arithmetical definition:
The sequence S1,S2,S3, … ,Sn, ... is approaching to (limit) S if for any given positive and arbitrary small number (e > 0) we can find a matched place (N) in the sequence, in such a way that the absolute value S-Sn (|S-Sn|) become smaller then any given epsilon, starting from this particular place in the sequence
(|S-Sn| < e for any N < n).
And then I clearly and simply explain in https://www.physicsforums.com/showpost.php?p=275250&postcount=318 why I do not share these reasoning with the rest of you.
Again, my work is in the most fundamental levels of the basic concepts of the language of Mathematics, and all I need is to show that I understand the reasoning behind these basic concepts, and I clearly showed that I understand the reasoning behind it.
Now after I showed it, I want you to show that you can understand my different point of view about these fundamental concepts.
And you have to understand that in this gentle level your technical skills cannot help you, but only your most simple ability to understand deep things, that cannot be thought by any external method.
It is like a swing in jazz, you have it or you don't have it, and no school can give you the swing.
So, I have a very simple question to you.
Can you take off your boxing gloves and try to understand my reasoning with your bear hands?
Lama said:
<List of excuses>
I didn't ask you if you agreed with it, I challenged you to prove that you actually understand math. Will you show that you do, admit that you don't, or continue to make excuses? I think you'll chose the last.
Lama, quoting definition you downloaded from the web does not prove you understand them. I agree with ex-xian, prove him and us that you know basic math by accepting his challenge.
Kaiser.
So you cannot do it, because you cannot understand anything of what I wrote to you in post #504.
Again I do not need to show that I know how to use your reasoning to prove things, all I need to show is that I understand the most fundamental reasoning behind it, and I clearly showed it in my previous post.
If you do not understand it then you cannot understand what is the meaning of fundamental work on the most basic concepts of the language of Mathematics.
By these words you show that you do not understand the meaning of the words 'basic Math', and so is ex-xian.
Basic Math is exactly what I am doing in my work, when you understand 'basic math' as basic techniques of your reasoning.
Your a ****ing retard, Lama!
Stick your head up your ass and eat your own **** if you like, but you won't get any here to enjoy the taste of it
Well arildno I like to eat @@@@@ more then **** , so you see we have a different taste.
Oh really. Then why did you write this?
Please demonstrate some fundamental mathematical idea, which can clearly show that I do not understand (again, not disagree with, but do not understand) its standard interpretation.
I freely admit that I don't understand much of what you write. It's total gibberish. Will you also admit that you don't understand math?
Once again, you change the meaning of words to suit yourself. You claimed that standard math is a shadow your system and that you have a strong, solid grasp on standard math. Personally, I think you were lying and I think it's been demonstrated by many people that you don't understand mathematics. Prove us wrong.
