The gravitational tug of the Sun and the Moon on Earth - a question
The discussion explores the gravitational effects of the Sun and Moon on Earth, particularly why there are two high tides each day. The gravitational pull from the Sun varies across the Earth, with stronger pull on the side closest to the Sun and weaker pull on the far side, leading to a differential effect that creates high tides. The participant seeks clarification on why the gravitational force from the Moon appears to push rocks on the far side away from it, rather than pulling them towards it. The explanation provided emphasizes that it's not the rocks being pulled away from the Sun, but rather the Earth being pulled away from the rocks due to varying gravitational forces. This understanding resolves the confusion about the direction of gravitational forces involved in tidal movements.
shirvanshah
Hi! When it comes to physics, I'm a total layperson (so, please, be kind ;-)), I actually study English, but recently my interest in physics has been growing more and more. So, yesterday I started watching the first of Feynman's Cornell University lectures. And that led me to the question: why there are two high tides each day? What's especially striking to me is that there are two high tides simultaneously, I mean, on both "sides" of the Earth at the same time. So, I tried to get some insight on that, and I've found the following paper: http://www.jal.cc.il.us/~mikolajsawicki/tides_new2.pdf
And what is quite perplexing here is the following passage:
Consider the point C on Earth closest to the Sun and the point F on a far side of Earth. The
Sun pulls harder on a unit mass at the point C, not as hard on a unit mass at Earth center O,
and weaker yet on a unit mass at point F. The acceleration as of Earth as a whole in free fall
towards the Sun is determined by the gravitational pull of the Sun on Earth’s center. Hence
the unit mass at C has a tendency to accelerate towards the Sun with acceleration as + as,
i.e. more than the center of Earth, while a mass at the far side F has a tendency to accelerate towards the Sun with acceleration as - as, i.e. to lag behind the center of Earth.
This difference in Solar gravitational pulls would have lead to a disintegration of Earth, had
Earth’s own gravity been to weak to hold Earth together. To an observer on Earth it would have looked like rocks at point C and F were lifted away from the surface of Earth.
And I believe it's a very similar case with the Moon's gravitational pull and this is why there are two high tides. So, my question is this - why the rocks at point F would be lifted away from the Sun and not pulled in the direction of Sun, that is, towards Earth's center? Why the direction of that force is not in the same direction as the gravitational pull of the sun (towards the Sun's center) but, as it seems, away from it?
I probably should have payed more attention to science in high school, but I would really appreciate a kind and an easy-to-grasp answer ;-).
Yes, but still I don't quite understand why the force of the Moon's gravitational pull on the side farthest from the moon is directed, as it seems, away from the moon, and not towards the moon and towards the Earth's center. It seems to me that on the side farthest from the Moon the force of the Moon's gravity and the force of the Earth's gravity have the same direction, so why they are subtracted rather than added?
I realize that there must be some profound misconception in what I wrote above, and I would be really glad to know what the misconception is exactly about.
It's not that rock F is pulled away from the Sun, it's that Earth is pulled away from rock F.
Think of it this way:
Three rocks, a, B and c are resting together, 93 million miles from the sun:
(SUN) . . . . . . . . . . aBc
a is 1kg
B is 10^23 kg
c is 1kg
a is pulled most strongly toward the Sun;
B is pulled toward the sun but less strongly than a;
finally, c is pulled toward the sun but less strongly than B.
The net effect is that
aBc separate neatly and evenly to become a B c.
See?
Hm... Is it really that simple? Well, it seems I get it now, thank you very much :D
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
