The horizontal speed of an object does not affect the time it takes to fall vertically?
  • Context: High School
  • Thread starter Thread starter user079622
    Falling object
The discussion centers around the relationship between horizontal speed and the time it takes for an object to fall vertically. Participants explore the implications of horizontal motion on vertical fall time, considering both idealized scenarios and real-world factors such as aerodynamics and reference frames.
  • Some participants argue that horizontal speed is irrelevant to the time it takes for an object to fall vertically, as only vertical forces affect fall time.
  • Others suggest that intuition may fail because real-world situations involve multiple factors, while idealized problems isolate specific aspects for clarity.
  • A participant mentions that the curvature of the Earth may become relevant at high speeds, implying that conditions can affect outcomes.
  • Some contributions highlight that aerodynamics can influence the time an object remains airborne, particularly in non-ideal scenarios like frisbees.
  • There are discussions about reference frames, with some participants noting that the perception of verticality can change depending on the observer's frame of reference.
  • A participant challenges others to demonstrate with equations that a ball fired from a moving cart will fall back into the cart, regardless of various parameters.
  • Some participants reference demonstrations from media, such as Mythbusters, to support their claims about non-intuitive outcomes.
Participants express differing views on the relevance of horizontal speed to vertical fall time, with no consensus reached. Some agree on the irrelevance of horizontal speed in idealized scenarios, while others emphasize the importance of real-world complexities.
Limitations include the dependence on idealized versus real-world scenarios, the need for specific definitions of verticality, and unresolved mathematical steps regarding the interaction of horizontal and vertical motions.
user079622
He didnt plug horizontal speed in any equation, which implies it is irrelevant for this problem.
My intuition say that if I throw a bullet from 1.5m height, with horizontal speed of 10m/s it will take less time to hit the ground, than if I shot this bullet from gun at 1000km/h in horizontal direction.
Why my intuition fail, why I am wrong?
The universe doesn't care about human intuition.
  • Love
Without put problem on paper, you will say that time duration is equal?
Yes, I can say it is true from my experience with shooting and ballistics. When we calculate the drop of a bullet fired horizontally, we take the horizontal flight time from the gun to the target, and use that time to tell us the vertical drop.*
* (ignoring air resistance slowing the horizontal motion of the bullet, which does need to be taken into account for longer shots in order to get a better approximation of the horizontal velocity)
Yes. Unless the speed is sufficient for the curvature of the Earth to become relevant.
That said, there is also aerodynamics to take into account.
Because your intuition is trained on real world situations (where many factors are at play), not idealized scenarios (which are meant to demonstrate one aspect in isolation, and are supposed to be easy to solve).
For a frisbee, the horizontal velocity obviously matters for the time it stays airborne, because of its aerodynamics, which is often neglected in idealized problems.
Watch this video of a classic demonstration. Is what you see consistent with your intuition?
This is the reason that the underlying laws of nature went undiscovered for so long. Newton saw what no one else had previously seen: that hidden beneath the variety and complexity of motion lay four laws - the three laws of motion and the law of gravitation.
Birds and aeroplanes apparently defy the law of gravity!
Yes, I know if I jump in train, I will land at same place if train travel at constant speed.
Do you think his discover of calculus is even bigger then laws of motion?
What if the train is not moving at constant speed, but it accelerating? Watch this especially the last part when the acceleration is provided by tilting the track away from horizontal. The result will be the same whether the cart is released from rest down the incline or given a push up the incline.
Ball is fired at angle in last part. Oblique shot
An angle with respect to what? "Oblique shot" does not explain much.
Respect to horizontal
If ball is fired vertically, it will fall behind truck.
Vertically according to whom?
If vertical with respect to the rest frame of the ground then yes, the truck will move away forward before the ball falls.
If vertical with respect to the truck then, to a first approximation, it will fall back into the truck. To a better approximation, Coriolis will do its thing.
Assume that the cart is moving down the incline with speed ##u## when the ball is fired with speed ##v## in a direction perpendicular to the incline. The angle of the incline is ##\theta##. Can you show with equations, not intuition, that the ball will fall back into the cart regardless of the values of ##u##, ##v## and ##\theta##? Ignore the Coriolis effect mentioned in the previous post.
The only forces affecting the time an object takes to fall vertically are vertical forces.
Think of forces induced by wings and parachutes, which retard a fall.
Examples of increased fall speeds:
-Peregrine falcons can reach vertical speeds of up to 200 mph when diving.
-Thrust from the engine allows special aircraft reach vertical speeds greater than free fall (dive bombers, aerobatic planes).
-The free end of a board that rotates about a pivot under the force of gravity will accelerate at a rate greater than g.
Vertically respect to ground, parallel with gravity direction.
No without help of textbook.
OK, this is not a class exam. Consult with your textbook and once you get your solution post it here. There are more than one ways to get the answer.
It's not about what 'vertical' means. It's about which reference frame measures the velocity to be vertical. Gravity has the same direction in all frames, but velocity vectors are frame dependent.
Mythbusters did this exact demonstration in Season 7, Episode 12. Just because something is non-intuitive doesn't mean that it's not true!
Maybe because your intuition is unconsciously assessing distance travelled to time.
  • · Replies 26 ·
15K
