The Landau-Zener transition & spin-flipping in an external field
  • Context: Graduate
  • Thread starter Thread starter omni-impotent
    Field Transition
The discussion focuses on the Landau-Zener transition and its relationship to spin-flipping in magnetic moments under an external bias field along the z-axis (Bz). The participants clarify that the Landau-Zener transition can be viewed as a specific instance of the Rabi transition when the perturbation is applied briefly. The spin-flip probability is expressed as exp(-2 π Γ), where Γ is defined as Bx²/(dΔE/dt), with ΔE representing the energy gap. The conversation also touches on the implications of applying a perturbation in the z-axis and introduces the concept of Majorana spin-flipping.
  • Understanding of quantum mechanics principles, particularly spin dynamics.
  • Familiarity with the Landau-Zener transition theory.
  • Knowledge of Rabi oscillations and their mathematical representation.
  • Basic concepts of magnetic fields and their effects on quantum states.
  • Research the mathematical derivation of the Landau-Zener transition.
  • Explore the implications of Majorana spin-flipping in quantum systems.
  • Study the effects of oscillating magnetic fields on spin states at the Larmor frequency.
  • Investigate the role of energy gaps in quantum transitions and their dependence on perturbations.
Quantum physicists, researchers in condensed matter physics, and anyone studying spin dynamics in magnetic fields will benefit from this discussion.
omni-impotent
Hello gentlemen,
I am trying to understand better processes that can cause "spin-flipping" to occur for magnetic moments in a bias field along the z-axis, Bz.
The application of a oscillating field in the xy-plane is well known to me. If the oscillating frequency is at the Larmor frequency, \omega_L = \gamma B then the probability of a spin-flip will be given by sin(\omega_R t), where \omega_R is the Rabi frequency and t is the duration time the field is applied for.
I am trying to understand the Landau-Zener transitions. When I try to search google, I just get lots of hits for quantum qubit transitions. If I am interpreting correctly, the LZ transition is almost just a special case of the Rabi transition if the perturbation is just for a short time? The excitation is normally treated as a perturbing field in the x-axis B_x which varies linearly. The spin-flip probability is something like exp(-2 \pi \Gamma), where \Gamma = \frac{B_x^2}{d\DeltaE/dt}. \DeltaE is the size of the energy gap and for the magnetic moment example, it is 2 \mu B. Am I right?
I am confused by this since why does the energy gap change if you're only applying a small perturbation in Bx?
Also, how can one treat a problem where the variations is in the z-axis? Something like a \delta_{B_Z}? Can this induce spin-flips? Can I use the Landau-Zener transition for this since \Delta_E changes? What if this extra \delta_{B_Z} causes the total BZ to go through zero?
ahhh... after some hours of searching, the phenomena I am referring to is called majorana spin-flipping. Anyone know anything about this?
  • · Replies 0 ·
  • · Replies 16 ·
