- Messages
- 15,028
- Reaction score
- 7,797
In most QM textbook there is.vanhees71 said:In the formalism there's no collapse
The same can be said for the wave function.vanhees71 said:The Bohmian trajectories are not observable. At least I don't have seen any measurement of the "Bohmian streamlines" behind a double slit for single electrons.
Read again the text you quoted. The first sentence shows that it must exist, while the second one considers the possibility that it doesn't exist. That's logical inconsistency, or more precisely a contradiction.martinbn said:What is the logical inconsistency?
- sorry - forgot to attach it! It's also in Mind, Matter and Quantum Mechanicsvanhees71 said:Could you give the source.
Is the attached PDF subject to copyright?AlexCaledin said:- sorry - forgot to attach it! It's also in Mind, Matter and Quantum Mechanics
Already the abstract of the forwarded pdf makes no sense. Quantum theory does NOT say that its completeness were incompatible with the objective existence of classical spacetime. To the contrary the standard quantum theory builds on classical spacetime descriptions (Newtonian or special relativistic, depending on whether you do non-relativistic quantum mechanics or relativistic quantum (field) theory). The Rules of Quantum Mechanics, defined by the realization of the observable algebras are based on the spacetime structure as defined by classical physics. E.g., the commutation relations between the position and momentum operators and thus the entire construction of non-relativistic quantum theory, formulated in one of its standard representations like Schrödinger wave mechanics, follows from the Galilei symmetry of Newton-Galilei spacetime. The same holds for relativistic QFT and the Standard Model of elementary particle physics, which looks as it looks because of the Poincare symmetry of Minkowski spacetime.AlexCaledin said:- sorry - forgot to attach it! It's also in Mind, Matter and Quantum Mechanics
Perhaps it's quite enough to know that a sort of Branching Spacetime interpretation is quite possible? or Hartle's Spacetime Alternatives? - anyway, the actual coarse grained reality is somehow chosen - with the spacetime - and it seems not very scientific to speculate how exactly the choice occurs - it makes the QM working, that's all...vanhees71 said:What we don't know is how to quantize the ... spacetime itself.
I would describe a couple of interpretations as minimal, e.g. I also think the Bayesian interpretation is minimal. In fact, I prefer it to Copenhagen, which has always seemed to come in various versions.Morbert said:I always thought the minimal interpretation was the "shut up and calculate" interpretation: If you set up an ensemble of identically prepared systems and specify a measurement procedure that generates data, QM will report the frequencies and correlations that will be present in the data.
