The principle of least Action proof of minimum
The discussion revolves around the principle of least action as presented in Feynman's Lectures on Physics. Participants are attempting to understand a specific statement regarding the mean square of deviations and its implications for proving that the path taken by a particle corresponds to an action of zero.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are exploring the relationship between mean values and mean squares, questioning the validity of certain mathematical inequalities. There is an attempt to prove the statement regarding mean squares and its relevance to the principle of least action.
There is ongoing debate about the correctness of the mathematical assertions made, with some participants pointing out potential errors in reasoning. The discussion includes attempts to clarify misunderstandings and to correct misconceptions about the inequalities involved.
Participants are grappling with the implications of negative values in their calculations, which complicates the application of the inequalities they are discussing. There are also issues related to the submission of content that may be affecting the flow of the discussion.
shakaman2
Reading Feynman The Principle of Least Action out of The Feynman Lectures on Physics, Vol 2. Link to text http://www.feynmanlectures.caltech.edu/II_19.html
So I'm having a problem proving that, section 19-2 5th paragraf, that
"Now the mean square of something that deviates around an average, as you know, is always greater than the square of the mean; ". The purpose of this was to illustrate the principle of least action. Then proving that the path that is taken by a particle is the one with Actions = 0, and the way to get to that path. Below is a comment that is underlined(sp?) made while discussing how to do this.
So definitions:
Numbers: [tex]x_1+...x_n[/tex]
Mean: [tex](x_1+...x_n)/n[/tex]
Mean square: [tex]((x_1+...x_n)/n)^2[/tex]
Square mean: [tex](x^2_1+...x^2_n)/n[/tex]
Kinetic Energy: KE
Potential Energy: PE
Action [tex]= S = \int_{t_1}^{t_2} (KE-PE) dt[/tex]
So i can prove for myself that the following is true:
[tex]((x_1+...x_n)/n)^2 \geq (x^2_1+...x^2_n)/n \quad \forall x_i \geq 0[/tex]
The problem here s that it is not always that [tex]x_i \geq 0[/tex]. Since we have [tex]v \in \mathbb{R}[/tex], and therefore can be less then 0. So when we later go to find the path that is right we can't minimize with respect to the action.
What am I missing here?
So definitions:
Kinetic Energy: KE
I hope you can't prove that
[tex]((x_1+...x_n)/n)^2 \geq (x^2_1+...x^2_n)/n \quad \forall x_i \geq 0 \; \Leftarrow \:\text{FALSE}[/tex]
because the exact opposite is true:
[tex]\frac{1}{n} \sum_{i=1}^n x_i^2 \geq \left( \frac{1}{n} \sum_{i=1}^n x_i \right)^2 \;\; \forall x_1, x_2, \ldots, x_n \in \mathbb{R}[/tex]
This follows from expansion and simplification of
[tex]\frac{1}{n} \sum_{i=1}^n (x_i - \bar{x})^2 \geq 0,[/tex]
where ##\bar{x} = \frac{1}{n} \sum_{i=1}^n x_i## is the average of the ##x_i##.
Yes sorry the [tex](...)^2[/tex] should be before the n [tex]\quad (x_1+...x_n)^2 /n \geq (x^2_1+...x^2_n)/n \quad \forall x_i \geq 0 \;[/tex]
Which I get from [tex](a^2+b^2) \geq (a+b)^2[/tex]
But when I try to edit I get:
The following error occurred:
Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator.
Was trying to wait it out.
You keep writing false things. It is not true that ##a^2 + b^2 \geq (a+b)^2##. Try putting ##a = b = 1## and see what happens.
  • · Replies 40 ·
  • · Replies 25 ·
