- 828
- 55
ThomasT said:That's understandably and, imho, unacceptably, vague. Nonlocality is defined by some (most? ... I don't know) quantum physicists as referring to entangled quantum states, which might ultimately refer to ftl propagations or not.
With respect to the OP, I'm not sure what you are asking. If one buys Leifer's argument, it's pretty clear which models PBR scraps. With respect to non-locality, some physicists (e.g. Bell, Maudlin, Laudisa, Norsen, etc.) interpreted Bell's theorem as already implying non-locality (ftl) irrespective of "realism" issues. Others, however, did not interpret Bell's theorem in that way. I think it has to be vague (e.g. "influence") because some have argued that non-locality does not imply incompatibility with relativity since it may depend on which interpretation of relativity is true. A Lorentzian interpretation of relativity (single preferred frame) is compatible with non-locality. Does this mean just some finite v>c or instantaneous influence? I think it implies the latter. Here's what Bell wrote on non-locality implied by his theorem:
I think it’s a deep dilemma, and the resolution of it will not be trivial; it will require a substantial change in the way we look at things. But I would say that the cheapest resolution is something like going back to relativity as it was before Einstein, when people like Lorentz and Poincare thought that there was an aether -a preferred frame of reference-but that our measuring instruments were distorted by motion in such a way that we could not detect motion through the aether...that is certainly the cheapest solution. Behind the apparent Lorentz invariance of the phenomena, there is a deeper level which is not Lorentz invariant...what is not sufficiently emphasized in textbooks, in my opinion, is that the pre-Einstein position of Lorentz and Poincar´e, Larmor and Fitzgerald was perfectly coherent, and is not inconsistent with relativity theory. The idea that there is an aether, and these Fitzgerald contractions and Larmor dilations occur, and that as a result the instruments do not detect motion through the aether - that is a perfectly coherent point of view...The reason I want to go back to the idea of an aether here is because in these EPR experiments there is the suggestion that behind the scenes something is going faster than light. Now if all Lorentz frames are equivalent, that also means that things can go backwards in time...[this] introduces great problems, paradoxes of causality, and so on. And so it is precisely to avoid these that I want to say there is a real causal sequence which is defined in the aether.”
More recently a number of "realist" spontaneous collapse and Bohmian interpretations that are Lorenz-invariant (and even narrative) have been developed:
http://arxiv.org/PS_cache/arxiv/pdf/1111/1111.1425v1.pdf
http://arxiv.org/PS_cache/quant-ph/pdf/0406/0406094v2.pdf
http://xxx.lanl.gov/abs/1002.3226
But I have come across some criticisms about these models as well (for example, Valentini). From Towler's site:
Valentini’s Aristotelian spacetime: Galilean invariance not a fundamental symmetry of the standard low-energy pilot-wave theory. The search for a Lorentz-invariant extension thus seems misguided. In Valentini’s view, the difficulties encountered in such a search are no reflection on the plausibility of the pilot-wave theory. Rather, they show that the theory is not being interpreted correctly. Pilot-wave theory then has a remarkable internal logic - both structure of dynamics, and operational possibility of nonlocal signalling away from equilibrium (see later) independently point to existence of natural preferred state of rest.
http://www.tcm.phy.cam.ac.uk/~mdt26/PWT/lectures/bohm5.pdf
