The relationship between pH and pOH at 70 ◦C/ 343.15 K
The discussion centers on the relationship between pH and pOH for pure water at 70 °C, exploring the necessary calculations and thermodynamic principles involved. Participants engage with concepts such as Le Châtelier's principle and the van 't Hoff equation, as well as the implications of temperature on pH values.
  • Homework-related
  • One participant states the known relationship at 25 °C is 14 = pH + pOH and seeks to find the equivalent at 70 °C.
  • Another participant suggests estimating the ion product of water (Kw) using thermodynamic data and mentions the van 't Hoff equation as a potential method.
  • A later reply confirms the use of the van 't Hoff equation and provides calculations leading to a value of Kw at 70 °C, resulting in a pH of approximately 5.5.
  • One participant expresses confusion over the use of logarithms in their calculations, specifically the distinction between natural logarithm (ln) and base-10 logarithm.
  • Another participant clarifies the logarithmic base used in their calculations, leading to a corrected pH value of 6.35.
Participants do not reach a consensus on the correct pH value for pure water at 70 °C, as initial calculations yield different results compared to the expected answer provided in the exercises. The discussion reflects uncertainty and varying interpretations of the calculations involved.
Participants note the dependence of the calculations on temperature and the assumptions made regarding the thermodynamic constants. There is also mention of potential errors in logarithmic calculations that affect the results.
ChristinaMaria
The relationship between pH and pOH, for pure water, at 25 ◦C is
14 = pH + pOH
What is the corresponding relationship between pH and pOH, for pure water, at 70 ◦C?
Le Châtelier's principle?
[H+][OH-] = 10-14
[10-7][10-7] = 10-14 (25 ◦C)
[10-n][10-m] = 10-b (70 ◦C)
ΔG◦ = ΔH◦ - TΔS◦ (?)
ΔG = ΔG◦ + RTln(Q) (?)
I have tried to use the formula ΔG = ΔG◦ + RTln(Q) for water at 25 ◦C to find the thermodynamic constant Q.
Result:
(at 25 degrees ) ΔG = -48.8 kJ/mol
I then tried to change the equation of ΔG to give Q:
Q = 10ΔG / ΔG◦ + RT
but I realized that I can't do this, as ΔG◦ is dependent on the temperature of the system.
I know that pH decreases at temperature increases due to Le Châtelier's principle. But I don't understand how I can use this to find a corresponding relationship to pH + pOH = ?
Thank you!
Are you asked to estimate Kw of water from known thermodynamic data (van 't Hoff's equation comes to mind), or do you just need the value (it is tabulated and not that difficult to find)?
We are probably supposed to use van'T Hoff's equation! I will try that. Thank you! :smile:
Hi again.
I thought I would give an update with my attempt to solve the problem.
I followed your suggestion and used the Van't Hoff equation:
6b566ffa2e3352acf5082c91ae882471fe7f8de6
With the following values:
ΔH⊖ = 56000 J/mol, K1 = 10-14, R = 8.214 J/mol K, T2 = 343.15 K and T1 = 298.15 Kln K2/10-14 = 2.99
K2/10-14 = 102.99 = 977.24
K2 = 977.24 * 10-14 = 9.8 * 10-12
=> (70 C/ 343.14K) [H+][OH-] = 9.8 * 10-12
pH + pOH = -log( 9.8 * 10-12 )
[H+] = sqrt( 9.8 * 10-12 ) = 3.13 * 10-6
pH = -log[H+] = 5.5My results:
the relationship between pH and pOH at 70 degrees C is:
and the pH of pure water at 70 degrees C is:
pH = -log[H+] = 5.5Unfortunately my results are different from the numerical answers given to us with the exercises, where it says that the pH should be 6.35.
I'm not sure what I did that made it wrong, but I know now that we are supposed to use the Van't Hoff equation as it was confirmed on our class' discussion board.
Thanks again!
ChristinaMaria said:
Hi again.
ln K2/10-14 = 2.99
What does "ln" mean?
I meant "ln" as the natural logarithm to K2/10-14. I then raised 10 to the power of K2/10-14 to remove the "ln". Is this part wrong?
:smile:
Update:
I understand what you mean now, I was supposed to raise e to the power of K2/10-14, not 10 to K2/10-14 like you would do with "log"..!
I used e instead of 10 as the "base", and got the correct answers pH + pOH = 12.7 and pH = 6.35 at 70 degrees C for pure water.
Thank you so much for the help!
12K
