The set of matrices that are their own inverse in R2
The discussion focuses on identifying all 2x2 matrices A that are their own inverses, leading to the equation A² = I. Participants explore the implications of the matrix's components, noting that the diagonal elements must be ±1 while the off-diagonal elements are zero. Algebraic attempts reveal that if a + d ≠ 0, then b and c must be zero, resulting in the conclusion that a and d are also constrained to ±1. The conversation highlights the need for clearer algebraic manipulation to fully derive the conditions for such matrices. Overall, the key takeaway is the relationship between the matrix components and their constraints for being their own inverses.
Elwin.Martin
Find all 2x2 square matrices A which are their own inverses.
A2=I
A=A-1
I know that the diagonal is comprised of 1s and or -1s and the other entries are zero but I can't seem to show it algebraically.
I went the weak way and did components...
I said A had rows of {a,b} and {c,d} and that A2=I
so
a2+bc=1
b(a+d)=0
c(a+d)=0
d2+bc=1
Now I know that the solution will have diagonals comprised of (+ or -)1 and the other two entries zero but I don't know how to do the algebra to get there =| I'll write down what I tried last night, any direction would be greatly appreciated!
So I said that
b(a+d)=0
c(a+d)=0
so either (a+d)=0 or b=0 and c=0...
so if we assume a+d=!0 then
b=0 and c=0
thus d2=1
and a2=1
so we'd have a=+-1,b=0,c=0,d=+-1
but if a+d=0
then a=-d
d2-a2=0
d=+-a but apparently the positive case is ignored since we assumed a+d=0 s0 d=-a again and I have nothing conclusive about b or c? O.o
Again, thank you in advanced for any and all advice...it's sad that my basic algebra skills are so weak...if someone could recommend a good algebra practice book that would also be appreciated. I think I'm worse at Algebra than everything else haha
Also if this thread needs to be moved just let me know, at my university Linear Algebra is beyond Calculus but this particular question is fairly simple.
Thank you again for your time
elwin
A2=I
A=A-1
so
a2+bc=1
b(a+d)=0
c(a+d)=0
d2+bc=1
Why do you think these are all the matrices? This isn't true.
So I said that
b(a+d)=0
c(a+d)=0
b=0 and c=0
thus d2=1
and a2=1
but if a+d=0
then a=-d
d2-a2=0
So you know you have a=-d. And you also know that a2+bc=1. So you can express b in terms of a and c...
Oh wow...that changes things quite a bit...
Thank you very much! I think I know what I'm doing wrong now.
elwin
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
