The Water Level Rises - Investigating the Melting Ice Cube
The discussion centers on the behavior of water levels when a floating ice cube melts. Participants assert that the water level will remain unchanged as the ice cube displaces an equivalent volume of water equal to its mass. Key points include the density of ice being lower than that of liquid water and the principle of displacement as articulated by Archimedes. Additionally, the conversation touches on the unique properties of water, particularly its density variations near 3 to 4 degrees Celsius.
  • Understanding of Archimedes' principle
  • Basic knowledge of density and buoyancy
  • Familiarity with the properties of water, especially near its melting point
  • Concept of crystalline structures in solids
  • Research the principles of buoyancy and displacement in fluids
  • Explore the unique thermal properties of water, particularly around 4 degrees Celsius
  • Study the molecular structure of ice and its implications on density
  • Investigate the effects of temperature on the density of liquids
Students studying physics, educators teaching fluid dynamics, and anyone interested in the physical properties of water and ice.
chemical
stuck in explaining this problem
A glass of water contains a large ice cube
the glass can hold no morw water
the ice is floating in the water
what will happen to the water level when the ice melts?
Originally posted by Guybrush Threepwood
the level will drop.
the ice has a density a bit lower than the water (that's why ice is floating).
http://www.its.caltech.edu/~atomic/snowcrystals/ice/ice.htm
I disagree. The ice cube is made wholly of water in a cryistaline form and therefore its mass although lower than liquid water would still diplace the same amount of water as is contained within the cube. if the cube melts the water from it will replace exactly the water that was originally displaced by the cube. therefore the level will remain the same.
Rog has it right. A floating object displaces its mass, a sunken one displaces its volume. Remember Archimedes.
Njorl
Is a perfect ice cube is made of wholly crystaline water? Aside from bubbles or such trapped particles, (which I am discounting), does the surface of the cube remain as a solid, or is it in a dynamic process of changing it's state?
It doesn't matter. Even if the ice cube was an ice bubble, the amount of water it displaces is identical [to the volume (melted) of the water contained in the ice].
I know the answer to this question! I did this question for my hw.
The answer is the water level will lower and then rise. I'm not sure at what temp, but water has a different density at certain temp. I think near 3 or 4 C, the density is lower than at other temp.
H20 does some strange things around its melting point, there is not really enough information in the problem to allow for those small effects. You would need to know the starting temperature of the water, and the ice, and their masses etc. If the thermal expansion coefficient of liquid water were monotonic, you could do what you say, but water is at it's maximum density at 4 degrees C I believe. Heat it or cool it from that point and it expands.
Njorl
13K
9K
16K
