How can I solve for v(t) when given F=Fo and v(t=0)=0?
To solve for v(t) given F = Fo and v(t=0) = 0, start by using the equation v² = v₀² + (2/m)∫(x₀ to x) F(x) dx. Substitute F = Fo into the equation, which simplifies the integral. The challenge lies in deriving a time-dependent expression for v(t), as the initial attempts did not yield a variable t. It is suggested to establish a relationship between v, x, and x₀, and to utilize the fact that v = dx/dt. Proper formatting in LaTeX is also advised for clarity in equations.
mch
See LaTeX[/B]
given that $$v^2 = v_o^2 + \frac{2}{m}\int\limits_{x_o}^x F(x) \ dx\ $$ find the speed v(t) and the position x(t) given that $$F = F_o$$ and $$v(t=0)=0$$. I tried plugging in $$F=F_o$$ for $$F(x)$$ in the above equation but solving this equation for v never yields any variable t. So my question is, how can I solve for v(t)?
There we go. Sorry if the spacing is a little off. I'm not good at LaTeX
First get a relation between ##v##, ##x##, and ##x_0##. Then note that ##v = \frac{dx}{dt}##.
mch the reason your equations are all spaced out is because you used the 'display math' delimiters which are double $ signs.
If you want to get in-line latex, which is what you need for some of your post, you can use double # instead.
  • · Replies 24 ·
