Theory behind gas tubes in lab experiments
This discussion focuses on the theory behind gas tubes used in laboratory experiments involving gases as reactants and products. Key points include the design of gas tubes, where entering tubes are typically longer than exiting tubes to facilitate gas transport through liquids, such as sodium hydroxide for CO2 removal. The conversation also clarifies that gas tubes operate based on pressure differences, not just suction, emphasizing the importance of tube length and positioning in achieving desired outcomes in gas handling.
  • Understanding of gas laws and pressure differentials
  • Familiarity with laboratory glassware, specifically round flasks
  • Knowledge of chemical reactions involving gases and liquids
  • Basic principles of gas collection and transport methods
  • Research the design and function of gas delivery systems in laboratory settings
  • Study the chemical properties and reactions of sodium hydroxide with CO2
  • Explore the principles of pressure differentials in fluid dynamics
  • Investigate various methods for gas collection and purification in experiments
Chemistry students, laboratory technicians, and researchers involved in gas handling and chemical experiments will benefit from this discussion.
Faiq
For chemical experiments that involve gases as reactant and products, gas tube are used for their transport.
Q1. Why are there differences in length of gas tube when in a round flask. In most case, entering tubes are longer than exiting tubes? Why is that?
Q2. Why is sometimes the entering tubes submerged in the liquid (that is present in the flask) whereas sometimes they aren't?
Q3. Are there any scenarios for which exiting tubes are submerged in the water/solvent?
Chemistry news on Phys.org
If you want the gas entering to go through a liquid, it needs the be longer to plunge in the liquid. On exit, you want only gas, so that tube has to be shorter, otherwise you will get liquid out.
There are different reasons why you would want a gas to first go through a liquid. For instance, a solution of sodium hydroxide can be used to remove CO2. I guess that in some cases the liquid is used to keep the gases from going back through the entry tube.
Okay perfect thank you.
Is it also possible to just suck out insoluble gases by plugining the delivery tube in water?
If you drink coke through a straw, do you suck out dissolved CO2, or the coke?
Both I think
Can you suck just the gas?
Likes jim mcnamara
No I don't think so.
Thank you very much.
So basically these gas tubes are nothing but suction tubes that suck due to a pressure difference.
Yes, the pressure difference is the driving force (note: it doesn't have to be suction, all that matters is that there is a pressure difference), there is nothing else happening.
21K
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 59 ·
12K
