Theory of machines homework problem
2 replies · 1K views · last reply
dorteam
New poster has been reminded to show the Relevant Equations and their work on the solution
The stroke of an internal combustion engine is 180 mm. The connecting rod is 3 times the crank length and has a mass of 40 kg. The mass of the reciprocating part is 12 kg. The centre of mass of connecting rod is 110 mm from the crank pin centre and the radius of gyration about an axis through the centre of mass is 148 mm. the engine runs at 320 rpm. Find the magnitude and the direction of the inertia force and the corresponding torque on the crank shaft when the angle turned by the crank is 2400 from the inner dead centre.
They're in the given question.
I couldn't do it
