Can Anisotropic Materials Have Asymmetric Thermal Conductivity Tensors?
Anisotropic materials can exhibit asymmetric thermal conductivity tensors, allowing heat to flow in directions not aligned with the temperature gradient. Graphene is a prime example, where heat flows efficiently along the layers but poorly across them. The discussion highlights that while heat flow can have components orthogonal to the gradient, it cannot be purely orthogonal. The tensor representing thermal conductivity must be positive definite to comply with thermodynamic laws, ensuring heat flows from higher to lower temperatures.
  • Understanding of anisotropic materials and their properties
  • Familiarity with thermal conductivity tensors
  • Knowledge of thermodynamic principles, particularly regarding heat flow
  • Basic mathematical skills for interpreting tensor equations
  • Research the thermal conductivity properties of graphene and other anisotropic materials
  • Study the mathematical representation of thermal conductivity tensors
  • Explore the implications of negative eigenvalues in thermal conductivity
  • Learn about the symmetry properties of tensors in material science
Material scientists, physicists, and engineers interested in the thermal properties of anisotropic materials, particularly those working with advanced materials like graphene.
dRic2
Hi, yesterday a professor of mine told me that if you have a temperature gradient along the x-axsis you could have heat flowing in the y direction. Mathematically it is pretty straightforward to find the thermal conductivity tensor required, but in real life can you name some materials that share this property ?
Science news on Phys.org
Essentially most anisotropic materials.
In more technical terms, if the decomposition of the symmetric traceless representation of rotations includes any singlets of the symmetry group of the material, you would have a harder time explaining why that material should not have an anisotropic thermal conductivity than why it should be isotropic. An example that I would expect to have anisotropic thermal conductivity is graphene, but I am no expert on thermal conductivity properties of materials - this is a pure symmetry argument. @Chestermiller ?
Consider even a uniform material.
If I have a long rod with both tips at 0C heat baths the rod will reach 0C. If I replace the ice at one tip with a blowtorch at the center of the tip's surface, a temperature gradient will develop along the rod. The surface of the rod along the long direction will also heat up. That means heat is being transferred radially, not just longitudinally.
Is that an example? If not, why not?
Heat in this case is being transferred radially because there will be a radial component of the temperature gradient.
No because the surface of the rod is initially at 0C and so there is also a radial component of the temperature gradient as the rod warms up that drives the heat flow.
Consider a very very thin slab of graphene. Heat will flow poorly through the layers of graphene while it will flow without problems along the layers. If you apply a temperature gradient across the faces of the slab I think you will only see an high resistance to the flow but I don't think you will measure heat flowing in the perpendicular direction. IMHO
PS: As I interpreted the statement of my professor the heat must flow only in the perpendicular direction, there is no heat flow along the direction of the temperature gradient
You will never get a flow that is exactly orthogonal to the gradient. However, you will get a flow that is not parallel to the gradient (i.e., it has a component that is orthogonal to the gradient) if you apply a temperature gradient that is not along one of the principal directions. In the case of graphene, apply a gradient that is not along the sheets and not perpendicular to the sheets, i.e., taking ##\vec n## to be the direction perpendicular to the sheets and ##\vec t## to be tangent to the sheets, you apply a gradient ##\nabla T = T^t \vec t + T^n \vec n##. Conductivity is a linear map from a temperature gradient to a heat flux density and therefore
\vec J = -K(\nabla T) = - K(T^t \vec t + T^n \vec n) = - T^t K(\vec t) - T^n K(\vec n).
The directions ##\vec t## and ##\vec n## are in the principal directions of the material so ##K(\vec t) = K^t \vec t## and ##K(\vec n) = K^n\vec n##, where ##K^t## and ##K^n## are material constants. It follows that
\vec J = - T^t K^t \vec t - T^n K^n \vec n,
which is not parallel to ##\vec J## unless ##K^t = K^n## or ##\nabla T## is along one of the principal directions. In your example, you took ##\nabla T## to be in a principal direction.
Edit: So, the underlying reason that the heat flow is not parallel to the temperature gradient is that it is much easier for the temperature gradient to drive a flow in a direction along the sheets as compared to driving a flow between the sheets.
That is obvious: it is just the vector nature of the flow. I was asking the other thing but you said it was impossible.
For example can a conductivity tensor be like this:
$$ \mathbf k = \begin {bmatrix}
0 & k_{xy} \\
k_{yx} & 0 \\
\end {bmatrix}
In this way if you take a temperature gradient only on the x direction
$$\mathbf Q = \mathbf k \cdot ∇ T =
\begin {bmatrix}
0 & k_{xy} \\
k_{yx} & 0 \\
\end {bmatrix} \cdot \begin{bmatrix} \partial_x T \\ 0 \end{bmatrix} = \begin{bmatrix} 0 \\ k_{yx} \partial_x T \end{bmatrix}
That would imply a negative eigenvalue and therefore heat could flow from lower to higher temperature, which breaks the laws of thermodynamics. The conductivity tensor must be positive definite.
If you think it is obvious I don't understand your confusion. The statement, as you have recounted it, does not say that the flux is exclusively in the y-direction.
If you have a composite material, the thermal conductivity can typically be anisotropic. For example, if you have rebar in cement, the preferred direction of heat conduction will be in the long direction of the rebar. This is analogous to the anisotropic mechanical properties of a composite.
Anisotropic crystalline materials:
https://arxiv.org/ftp/arxiv/papers/1809/1809.04762.pdf
https://journals.aps.org/prb/abstract/10.1103/PhysRevB.66.064525
https://dspace.mit.edu/bitstream/handle/1721.1/4445/rle-tr-377-04740983.pdf?sequence=1
I think I solved it. Probably I misunderstood what the professor said: tomorrow I'll talk to him.
Can you tell me more about the problem of negative eigenvalues because I didn't get it very much.
Thanks to everyone for the replies. :D
In essence, if you have a conductivity on the form you suggested, then it would have negative eigenvalues. This would mean that there is a direction in which you can apply a temperature gradient and get heat to flow in the same direction as the gradient, i.e., from low to high temperature. If you can do this you break the laws of thermodynamics.
I got it now. I have one more question : Does the tensor need to be symmetric ? I'm a bit confused over this one... Is this property shared by anisotropic materials linked to the symmetry of the tensor ?
Even if the material is anisotropic, the thermal conductivity will typically be symmetric, with 3 real principal- directions and magnitudes.
  • · Replies 16 ·
14K
  • · Replies 16 ·
  • · Replies 26 ·
