Thermal Equilibrium and Longitudinal Relaxation
Shinnobii
Problem 6.2 from Magnetic Resonance Imaging: Physical Principles and Sequence Design.
Show that [itex]M_o \approx \rho_o \frac{s(s+1)\gamma^2\hbar^2}{3kT}B_o[/itex]
[itex]M_o = \rho_o \gamma \hbar \frac{\sum m_s e^{m_s(\hbar w_o / kT)}}{\sum e^{m_s(\hbar w_o / kT)}}[/itex],
where [itex]m_s[/itex] is the magnetic quantum number.
Use the fact that [itex]kT >> \hbar w_o[/itex],
let [itex]\alpha = \frac{\hbar w_o}{kT}[/itex].
Then [itex]e^{\alpha m_s} \approx 1 + \alpha m_s[/itex].
[itex]M_o = \rho_o \gamma \hbar \frac{\sum m_s(1 + \alpha m_s)}{\sum (1 + \alpha m_s)}[/itex],
but [itex]\sum m_s = 0[/itex], therefore
[itex]M_o = \rho_o \gamma \hbar \frac{\alpha \sum (m_s^2)}{1 + 0}[/itex].
Assuming the above is correct. Am I correct that [itex]\sum m_s^2 = s(2s+1)(s+1)[/itex]?
If so, I get,
[itex]M_o = \frac{\rho_o \gamma^2 \hbar^2 B_o}{kT} s(2s+1)(s+1)[/itex],
since [itex]w_o = \gamma B_o[/itex].
Clearly this is not the correct form, where have I gone wrong?
Welcome to PF!
You did not evaluate the sum in the denominator correctly. ##\sum 1 \neq 1##
Almost. You're off by a simple numerical factor. See http://mathschallenge.net/library/number/sum_of_squares
Thanks, rookie mistakes. . .
[itex]\sum 1 = (2s + 1)[/itex], since summing from -s to s.
and I forgot a factor a 3
[itex]\sum m_s^2 = \frac{s(2s+1)(s+1)}{3}[/itex] .
Thanks for pointing those out to me!
