This discussion focuses on calculating the expected heat exchange between flowing groundwater in gravel/clay soil and glycol fluid in a 1 1/4" plastic pipe for a horizontal geo heat pump system. Key factors influencing this calculation include the pipe wall thickness, conductivity of the plastic and glycol, flow rate, and the initial temperature of the glycol. The ambient temperature of 45 degrees Fahrenheit is considered as a reference for the incoming glycol temperature. The goal is to determine the necessary pipe sizing, flow rate, and heat exchange parameters to ensure the system's financial viability for residential heating.
- Understanding of thermal conductivity principles
- Familiarity with geo heat pump systems
- Knowledge of fluid dynamics, particularly turbulent flow
- Experience with glycol properties and behavior in heat exchange
- Research the thermal conductivity of glycol and plastic materials
- Learn about the design and operation of horizontal geo heat pump systems
- Investigate methods for calculating heat exchange rates in piping systems
- Explore fluid dynamics principles related to turbulent and laminar flow
Engineers, HVAC professionals, and homeowners planning to implement geo heat pump systems for residential heating will benefit from this discussion.
