Thermal exchange calculations between water/glycol
This discussion focuses on calculating the expected heat exchange between flowing groundwater in gravel/clay soil and glycol fluid in a 1 1/4" plastic pipe for a horizontal geo heat pump system. Key factors influencing this calculation include the pipe wall thickness, conductivity of the plastic and glycol, flow rate, and the initial temperature of the glycol. The ambient temperature of 45 degrees Fahrenheit is considered as a reference for the incoming glycol temperature. The goal is to determine the necessary pipe sizing, flow rate, and heat exchange parameters to ensure the system's financial viability for residential heating.
  • Understanding of thermal conductivity principles
  • Familiarity with geo heat pump systems
  • Knowledge of fluid dynamics, particularly turbulent flow
  • Experience with glycol properties and behavior in heat exchange
  • Research the thermal conductivity of glycol and plastic materials
  • Learn about the design and operation of horizontal geo heat pump systems
  • Investigate methods for calculating heat exchange rates in piping systems
  • Explore fluid dynamics principles related to turbulent and laminar flow
Engineers, HVAC professionals, and homeowners planning to implement geo heat pump systems for residential heating will benefit from this discussion.
mwcon
I am trying to determine the expected heat exchange between flowing ground water in gravel/clay soil (that runs on top of blue clay) and glycol fluid in plastic pipe (1 1/4"). For my current interest, estimated ground water temperature of 60 degrees seems best. I am trying to determine the efficacy of a horizontal geo heat pump system for a residence. Outside ambient temperature would be 45 degrees.
Michael
Science news on Phys.org
Michael
These are the other relevant factors:
The thickness of the pipe wall (is 1.25 the i.d. or the o.d.?)
The conductivity of the plastic
The conductivity of glycol
The flow rate
Whether the flow will be turbulent
The pipe length
The initial temperature of the glycol
The lateral flow rate of the water
Why do you mention the ambient temperature? Is that the initial glycol temperature?
My instant reaction is that the pipe is rather fat. You need a long narrow pipe with a thin wall. The choice of material could be significant.
If there's limited room in the watercourse, it's best to have the glycol flowing in the opposite direction to the water. I.e. the glycol starts at the end where the water may have been cooled somewhat by earlier glycol.
Thanks for responding. I realized after posting that it was a pretty complicated question. I am trying to determine if a horizontal ground loop geo heat pump system can work for heating a house that I am planning on building. The pipe size is the standard tubing that is used in these applications if copper isn't used. The reason for listing ambient temperature is I thought that this was the best approximation for the incoming glycol tempurature. The BTUs per foot will determine the length of the piping but I am anticipating about 1800 lineal feet of double tubing. I don't know the lateral flow of the ground water. When I have excavated a discovery trench, it ran like a small stream over the blue clay. My hope in asking this question is that I would be able to identify 'range' data for the various categories to determine what range (pipe sizing, flow rate and heat exchange) I would have to fit into to make the project work financially.
My reason for phrasing the question as I did was that the heat exchange data would help me determine the pump sizing and the cost for running the pump to the exchanger in the basement. Thanks again. Michael
  • · Replies 40 ·
10K
