Thermal Expansion to Retain a Bolt
The discussion focuses on the thermal expansion properties of aluminum and steel when fitting a 1" aluminum rod into a steel structure. A 0.001" reduction in drill size requires a temperature difference of approximately 200°C due to the coefficients of thermal expansion (17 x 10-6 for aluminum and 11 x 10-6 for steel). The connection formed by sliding the aluminum and steel together at high temperatures will be permanent, as restoring the thermal difference after contact is nearly impossible. Proper alignment during the sliding process is crucial to ensure a secure fit.
  • Understanding of thermal expansion coefficients for metals
  • Knowledge of machining processes for precise drilling
  • Familiarity with the properties of aluminum and steel
  • Basic principles of thermal dynamics in engineering
  • Research the thermal expansion coefficients of various metals
  • Learn about machining techniques for achieving precise tolerances
  • Explore methods for achieving thermal fits in engineering applications
  • Study the effects of temperature on material properties during assembly
Mechanical engineers, materials scientists, and anyone involved in assembly processes requiring thermal fits between metals will benefit from this discussion.
christian everett
I have 1" aluminum rod and I want to dril a hole in a steel structure for the bolt.
If I have a 1" drill and take .001" inches off of it at the machine shop, so that it is now 0.998 inches, there will have to be about a 200°C difference in temperature between the two articles (aluminum having a coefficeint of expansion of 17 x 10-6 and steel 11 x 10-6) which shouldn´t be a problem.
There will be some mechanical retention (a bolt passing though both structures), but I was wondering if I am able to slide them together before they cool off and/or heat up how secure would this retention be withiut the mechanical retention (say it´s just one inch of length where they meet).
I show aluminum at 0.000023 - so you would need to cool it to about 120C.
https://www.engineeringtoolbox.com/linear-thermal-expansion-d_1379.html
It would be a very firm connection. Since restoring that thermal difference would be nearly impossible once the metals were in contact, it would be permanent.
Of course, slide them together smoothly. Once they bind, that's it.
  • · Replies 16 ·
