Thermal Insulation Solution for Aluminium Plates
The discussion focuses on finding effective thermal insulation solutions for controlling heat transfer between two aluminium plates, one at 250°C and the other at 150°C. Suggestions include using a thin sheet of copper to create a variable area for heat transfer and connecting it to an external heat sink, such as an ice bath. Additionally, a fiberglass textile is recommended for its cost-effectiveness and ability to significantly reduce temperature transfer. These materials are essential for maintaining optimal temperature differences in thermal management applications.
  • Understanding of thermal conductivity and insulation materials
  • Familiarity with heat transfer principles
  • Knowledge of aluminium properties and applications
  • Experience with thermal management systems
  • Research the thermal properties of fiberglass textiles for insulation
  • Explore the use of copper sheets in thermal management applications
  • Investigate external heat sink designs, particularly ice baths
  • Learn about advanced thermal insulation materials and their applications
Engineers, materials scientists, and anyone involved in thermal management or insulation solutions for high-temperature applications.
kubixxx
Hi everybody,
For one project, I need to find a material to control the heat transfer between two plates of aluminium by adding a plate or something in between. I'm so looking for a material which can help to reduce the heat transfer between the two plates (one about 250°C and the other about 150°C)
Any idea or what to use in between the two plates? As the distance between the plates should be as small as possible...
Thanks for your help!
Max
How about a thin sheet of copper that can can be moved into block a variable area of the plates. The copper in turn should be connected to an external heat sink of some sort (ice bath?). The copper will provide a path for excess heat to leave the plate system.
try a fiberglass textile. It should be able to knock the temperature in half. It isn't all that hot so you can probably find it cheap.
http://www.avsind.com/fiberglassfabrics.html
