Thermal properties of ice cream
The discussion focuses on the thermal properties of ice cream, specifically thermal conductivity and latent heat, and their variation with temperature. Key values provided include the latent heat of fusion at 210.14 J/kg, thermal conductivity at 4°C as 0.694 W/m-K, and at -26°C as 0.993 W/m-K. The density of ice cream is noted as 568 kg/m3, with specific heat values of 2.948 J/kg-K at 4°C and 1.629 J/kg-K at -26°C. The conversation emphasizes the importance of considering air overrun in density calculations and suggests using ANSYS FLUENT for computational analysis.
  • Understanding of thermal properties, specifically latent heat and thermal conductivity.
  • Familiarity with density calculations in two-phase mixtures.
  • Knowledge of ANSYS FLUENT for computational analysis.
  • Basic principles of thermodynamics relevant to phase changes.
  • Research the impact of temperature on the thermal properties of ice cream.
  • Explore density calculations for two-phase mixtures using volume fraction methods.
  • Learn about the use of ANSYS FLUENT for thermal analysis in food engineering.
  • Investigate alternative substances for thermal property analysis in similar projects.
Mechanical engineers, food scientists, and researchers involved in thermal analysis and computational modeling of food products, particularly ice cream.
sonu_123
i need some conceptual help for my final year project...
what are the thermal properties of ice cream?? Specifically the thermal conductivity and latent heat and the relation of it's variation with temperature...
i'll be adding a copy of my abstract for better understanding. oh and yeah I'm a mechanical engineer by the way...
I'm really sorry but that doesn't help me much as I've already made use of GOOGLE search and GOOGLE SCHOLAR for the values. What I have in my hand are the thermal properties at a constant temperature. I need a relation that tells me how those properties vary with temperature.
S. No Name of the Constant Value
1. Latent Heat of Fusion of Ice Cream 210.14 J/kg
2. Density 568 kg/m3
3. Specific Heat of Ice Cream at 4°C 2.948 J/kg-K
4. Specific Heat of Ice Cream at -26°C 1.629 J/kg-K
5. Thermal Conductivity of Ice Cream at 4°C .694 W/m-K
6. Thermal Conductivity of Ice Cream at -26°C .993 W/m-K
Assuming you're after fairly rough-and-ready engineering values, I'll try offering some comments:
1. The enthalpy of fusion is a rather weak function of temperature. For most engineering purposes, assuming it's temperature independent is not a bad approximation.
For the rest of the comments below, I have to assume you know how much overrun (that is, included air) you have. Commonly ice cream runs about 25-30% air by volume. I hope you won't say there isn't any, because if you did, your "ice cream" would be more like a solid block of flavorful ice.
Anyhow:
2. Density of a two phase mix, which is essentially what you have here, is often estimated as a volume fraction weighted average of the components. Thus, if you know your ice cream is (let's say) 25% by volume air, you can get the air density at atmospheric pressure and the desired temperature by the ideal gas law. The "liquid" part of it-that is, the actual freeze mix of milk, flavoring, sweetener, and whatnot-could be reasonably approximated by the density of milk, tables/correlations for which are likely available from agricultural extension services, among other places. Put those data together in a volume fraction-weighted average for various temperatures and there you have your density as a function of temperature.
I'll follow with more comments later. Gotta go right now.
Well...That data was very helpful...
I have completed my Under-Grad Project but need even more help as I am working on the same thing for my Masters. Suggestions on what other substances can be used for the analysis would be very helpful too.
I am planning to perform the computational analysis using ANSYS FLUENT this time as I have worked on ANSYS APDL Mechanical the previous time. So help/tutorials regarding the same would also be appreciated.
Apologies. Didn't see this thread until today and didn't see the date, either.
Anyhow: I know of two articles published about 9 years ago that address these topics pretty well. Send me a PM with your e-mail and I can provide PDFs of these articles if you're interested.
  • · Replies 26 ·
  • · Replies 16 ·
14K
