Thermal resistances adding formula
4 replies · 2K views · last reply
LinearMan
Prove a rule for adding of Thermal resistances
for: A)R1 and R2 in Series
B)R1 and R2 in Parallel
According to the book the result should be :
A) R = R1 + R2
B) 1/R = 1/R1 + 1/R2
So i thought we can get some ideas from the theory of Electrical resistance because these formulas are similar for example here: http://www.grc.nasa.gov/WWW/k-12/airplane/ohmrser.html .
However, I don't know how to start (in Thermodynamics there is no Electric current etc., so we can hardly use Ohm´s formula like in previous case).
Thanks for help
The thermodynamic analog of current is the Heat Current defined as the rate of flow of heat through the material and the analog of voltage is temperature difference
Not exactly but...
heat flow = ΔT/Thermal Resistance
which is similar to
Current = ΔV/Electrical Resistance
I'll let you work out the units.
