Thermal resistances adding formula
  • Thread starter Thread starter LinearMan
    Formula Thermal
The discussion focuses on proving the formulas for adding thermal resistances in series and parallel configurations. For resistances in series, the total thermal resistance is the sum of individual resistances (R = R1 + R2). In parallel, the total resistance is calculated using the formula 1/R = 1/R1 + 1/R2. The conversation draws parallels between thermal resistance and electrical resistance, noting that heat flow corresponds to thermal resistance similar to how current relates to electrical resistance. The analogy helps clarify the concepts despite the differences in the underlying physics.
LinearMan
Prove a rule for adding of Thermal resistances
for: A)R1 and R2 in Series
B)R1 and R2 in Parallel
According to the book the result should be :
A) R = R1 + R2
B) 1/R = 1/R1 + 1/R2
So i thought we can get some ideas from the theory of Electrical resistance because these formulas are similar for example here: http://www.grc.nasa.gov/WWW/k-12/airplane/ohmrser.html .
However, I don't know how to start (in Thermodynamics there is no Electric current etc., so we can hardly use Ohm´s formula like in previous case).
Thanks for help
The thermodynamic analog of current is the Heat Current defined as the rate of flow of heat through the material and the analog of voltage is temperature difference
OK, thank you.
I get it
Not exactly but...
heat flow = ΔT/Thermal Resistance
which is similar to
Current = ΔV/Electrical Resistance
I'll let you work out the units.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
