How Does Constant Temperature Affect Heat Transfer in a Piston-Cylinder Device?
  • Thread starter Thread starter CRich
    Final Review
The discussion focuses on the heat transfer in a piston-cylinder device where air is maintained at a constant temperature of 300K while the volume changes from 1m³ to 0.1m³. The initial pressure is 100kPa, and the valve opens at 200kPa. Key calculations include determining the heat transfer amounts Q1-2 and Q2-3, as well as the initial and final mass of air using the ideal gas law. The equations used include the work done W={integral}Pdv and the energy conservation equation Q-W=0, confirming the process is frictionless and isotropic.
  • Understanding of ideal gas laws and equations
  • Familiarity with thermodynamic processes and heat transfer
  • Knowledge of specific heats, particularly Cp and Cv
  • Ability to interpret p-V and T-V diagrams
  • Study the derivation and application of the ideal gas law in thermodynamic systems
  • Learn about the principles of heat transfer in closed systems
  • Explore the concept of isotropic processes in thermodynamics
  • Investigate the calculation of work done in variable volume processes
Students studying thermodynamics, mechanical engineers working with piston-cylinder systems, and anyone interested in heat transfer principles in closed systems.
CRich
T1=300K
P1=100kPa
V1=1m^3
T1=T2=T3
P2=P3=200kPa
V3=0.1m^3
Q: Air initially at 300kpa is contained inside a piston-cylinder device with a volume of 1m^3. The cylinder is equiped with a check valve allowing air to escape when the air pressure reaches 200kPa. An extrernal force pushes the frictionless piston slowly until the final volume reaches 0.1m^3. Durring this entire process, the air temp is maintained at 300K by heat transfer. To determine the heat transfer answer the following questions. Air is assumed to be an ideal gas with constant specefic heats, cp=1 kJ/kg-K, cv=0.713 kJ/kg-K.
(a) skecth (p-V) (T-V) diagrams [no problem I got those]
(b) find the heat transfer amount by the time when the valve opens so...Q1-2?
(c)Write down the energy conservation equation after the valve opens [I got this one too]
(d)Fing the inital and final mass of air
(e)Find the heat transfer amount after the valve opens until the final state so...Q2-3?
W={intergral}Pdv
Q-W=0 ===> Q=W
b/c it is frictionless it is an isotropic process
s1=s2
k=Cp/Cv
PV=RT
(b)for Q1-2 I tried
Q1-2=mT(s2-s1)=mT(Cpln (T2/T1)-Rln(P2/P1)) = -69.29 ... since s1=s2 I'm unsure if this equation is correct
I also tried Q1-2=mP(V2-V1) ... however I have 2 different Ps
So I also tried Q=W={the intergral from 1-2}pdv = m{the intergral from 1-2}C/V^k
(d)m=PV/RT => m1=1.161 m3=0.232 does m1=m2? ... I alos found? v2= (RT2)/P2=.4305?
(e) Q2-3=m2P(V3-V2) ... I think this equation is correct but I think I'm missing something...
anyone please... Just point me in a different direction...I'm horribly stuck and frustrated ... any direction any idea I'll try it!
11K
  • · Replies 20 ·
21K
  • · Replies 26 ·
