Thermodynamic differental relations problem
4 replies · 2K views · last reply
knowlewj01
Assuming V is a function of P and T such that
[itex]V = V(P,T)[/itex]
express the differential changes in volume due to differential changes in Temperature and pressure, what is the fractional/relative change?
since V is a function of P and T:
[itex]dV = \frac{\partial V}{\partial T} dP + \frac{\partial V}{\partial P} dT[/itex]
so we can say:
[itex]\left[\frac{dV}{dP}\right]_T = \frac{\partial V}{\partial T}[/itex]
and
[itex]\left[\frac{dV}{dT}\right]_P = \frac{\partial V}{\partial P}[/itex]
is this correct or have i read the question wrong, I am not really sure what I'm doing.
I'm not sure what you're doing either. Where does your first equation in the solution come from? Typically one writes
[tex]dV=\left(\frac{\partial V}{\partial P}\right)_T\,dP+\left(\frac{\partial V}{\partial T}\right)_P\,dT[/tex]
Ah, i got it the wrong way around then. Makes slightly more sense now.
so we are looking for fractional change, ie. [itex]\frac{dV}{V}[/itex]
so if we say that:
[itex]dV=\left(\frac{\partial V}{\patial P}\right)_T dP + \left(\frac{\partial V}{\partial T}\right)_P dT[/itex]
then divide by V to get fractional change:
[itex]\frac{dV}{V}=\frac{1}{V}\left(\frac{\partial V}{\patial P}\right)_T dP + \frac{1}{V}\left(\frac{\partial V}{\partial T}\right)_P dT[/itex]
now i notice that:
[itex]\frac{1}{V}\left(\frac{\partial V}{\partial T}\right)_P[/itex] is the coeficcient of thermal expansion [itex]\alpha[/itex]
and
[itex]\frac{1}{V}\left(\frac{\partial V}{\partial P}\right)_T[/itex] is negative coeficcient of isothermal compression [itex]-\kappa_T[/itex]
so this can be re-written as:
[itex]\frac{dV}{V} = \alpha dP - \kappa_T dT[/itex]
i think this is right.
Thanks for pointing that out, would have been scratching my head all night otherwise ;)
