Thermodynamic Identities Proof - Gibbs and Helmholtz
32 replies · 11K views
TFM
Use the definitions of Helmholtz free energy, F, and Gibbs free energy, H, together with the thermodynamic identity, to show that
[tex]S = -(\frac{\partial F}{\partial T})_V[/tex] and [tex]S = -(\frac{\partial F}{\partial T})_P[/tex]
Then use those definitions again, and the expressions above, to show that
[tex]U = -T^2 \left(\frac{\partial (F/T)}{\partial T} \right)_V[/tex] and [tex]H = -T^2 \left(\frac{\partial (G/T)}{\partial T} \right)_P[/tex]
These equations are known as the Gibbs-Helmholtz equations and are useful in chemical thermodynamics.
Helmholtz:
[tex]F = U - TS[/tex]
Gibbs:
[tex]G = H - TS = U - TS + PV[/tex]
I have succesfully done the first part (showing S = F/T...) But I am stuck on the second.
I asked the ;ectuirer, whop said I should first work backwards, and do df/DT, and insert into the equation. This has given me?
[tex]F(T) = V - TS[/tex]
[tex]\frac{\partial F}{\partial T} = -S[/tex]
insert:
[tex]U = -T^2 \left(\frac{-S}{\partial T} \right)_V[/tex]
now the thermodynamic identity is:
dU = Tds - pdv
I do I get rid of the squared part?
because if I just differentiate T squared, I get 2T,
so this could leave me with:
[tex]U = -2T \left(-S} \right)_V[/tex]
but this doesn't make the S a ds? and I have a factor of 2?
Any ideas?
Many thanks,
TFM
I would use the chain rule to evaluate
[tex]\left(\frac{\partial (F/T)}{\partial T}\right)_V[/tex]
which will give you two terms. Then plug in [itex]F=U-TS[/itex], which leads to the desired first expression. The same approach works for the H-G pair.
Okay, so using chain rule:
[tex]\frac{\partial \frac{F(T)}{T}}{dT}[/tex]
Would the quotient rule not be best:
[tex]u = F(T), v = T, du/DT = F'(t), dv/dT = 1[/tex]
giving:
[tex]\frac{TF'(T) - 1F(T)}{T^2}[/tex]
Plug in F = U - TS, F' = -S
[tex]\frac{T(-S) - U - TS}{T^2}[/tex]
[tex]\frac{-TS - U - TS}{T^2}[/tex]
[tex]\frac{-2TS - U}{T^2}[/tex]
Reinsert:
[tex]U = -T^2 \left(\frac{-2TS - U}{T^2} \right)_V[/tex]
This cancels to:
[tex]U = -2TS - U[/tex]
[tex]2U = -2TS[/tex]
[tex]U = -TS[/tex]
I don't think this is right...?
giving:
Reinsert:
This cancels to:
[tex]U = -TS[/tex]
Try this approach,
First divide F by T. Then differentiate the answer. Then plug in the thermodynamic identity for dU. Rearrange, and let N and V be constant. This should give you the right answer.
So when you say divide F by T, would thuis be F/T, or do we use F = U - TS, giving U/T - S?
You want both of those.
Okay, so
F/T = U/T - S
put into equation:
[tex]U = -T^2 \left(\frac{\partial (\fracd{U}{T} - S)}{\partial T} \right)_V[/tex]
differentiating this gives:
[tex]U = -T^2 \left(U)_V[/tex]
TFM said:
Okay, so
F/T = U/T - S
put into equation:
What you want is this;
[tex]\frac{\partial (F/T)}{\partial T}=\frac{\partial (\frac{U}{T} - S)}{\partial T}[/tex]
Then think what is d(U/T)/dT?
You made an arithmetic error in post #3. You're almost there.
That is strange we posted at exactly the same time. Are you my long lost twin brother? :wink:
Would it be U/T^2 ?
TFM said:
Would it be U/T^2 ?
That wold be part of it, although I think it should be negative U/T^2. Use the quotient rule and remember that you can't actually differentiate U so you have to leave it as dU/dT.
Okay, so using the quotient rule:
U = U (:rolleyes:)
V = T
du/dt = du/dt
dvdt = 1
thus:
[tex]= \frac{U - Tdu/dT}{T^2}[/tex]
Look okay now?
U = U (:rolleyes:)
V = T
du/dt = du/dt
dvdt = 1
thus:
Look okay now?
YOur quotient rule is back to front I believe. It should be (the following are for the general case);
[tex](\frac{u}{v})'=\frac{u'*v-u*v'}{v^{2}}[/tex] Note where the primes are, differentiate top times bottom, then take away the derivative of the bottom times the top and divide the whole lot by the bottom squared.
Once you've changed that let dU=identity and the rest is just rearranging.
Edit: I don't mean dU=1, I just mean the thermodynamic identity for dU, which you must have used earlier.
Okay, so it should have been:
[tex]\frac{dU/dT T - U}{T^2}[/tex]
so now the thermodynamic identity:
dU = Tds - pdv
so now I have to rearrange
into dU = , then replace du with the thermo identity, and solve?
dU = Tds - pdv
It would be easier if you just substituted for dU in the differential equation and solved. Don't forget the -dS/dT term from earlier when you put everything back together.
so,
dU = Tds + pdV
sub into:
[tex]\frac{(Tds + pdV/dT) T - U}{T^2}[/tex]
this will give:
[tex]\frac{T^2 ds/dT + pT dV/dT - U}{T^2}[/tex]
Thats right. Now all you have to do is simplify and you will have the right answer.
Okay so:
break it down into:
[tex]\frac{T^2 ds/dT}{T^2} + \frac{PT dV/dT}{T^2} - \frac{u}{T^2}[/tex]
[tex]\frac{ds}{dT} + \frac{P dV/dT}{T} - \frac{u}{T^2}[/tex]
[tex]\frac{ds}{dT} + \frac{P dV/dT}{T} = \frac{u}{T^2}[/tex]
Okay so far?
TFM said:
Okay so:
break it down into:
Okay so far?
Not sure about the equals sign here, don't forget this is part of the rhs of the equation,
d(F/T)/dT=d/dT(U/T-S)
Okay, so:
[tex]\frac{d(F/T)}{dT} = \frac{ds}{dT} + \frac{P dV/dT}{T} - \frac{u}{T^2}[/tex]
It doesn't look very similar yet though?
the ds/dt Will cancel, because we had a -ds/dt earlier on, from the F/T, so:
[tex]\frac{d(F/T)}{dT} = \frac{P dV/dT}{T} - \frac{u}{T^2}[/tex]
Does this look okay?
That is exactly right, it's what you want. Now if you fix V constant what happens to dv/dt?
well, the dv will cancel if V is constant, thus:
[tex]\frac{d(F/T)}{dT} = -\frac{u}{T^2}[/tex]
this rearranges to give:
[tex]u = -T^2 \frac{d(F/T)}{dT}[/tex]
Which is what we was meant to find!
Thats good, so now for the second one,
I assume I need to start of by doing G/T:
G = H - TS
thus:
[tex]G/T = H/T - S[/tex]
[tex]H = -T^2 \left(\frac{\partial (H/T - S)}{\partial T} \right)_P[/tex]
now this will give:
[tex]\frac{partial H/T}{\partial T} - \frac{\partial S}{\partial T}[/tex]
I assume I need to use quotient rule again,
u = H, du/dT = dH/dT
v = T, dv/dT = 1
giving:
[tex]\frac{\frac{dH}{dT}T - H}{T^2}[/tex]
[tex]\frac{\frac{dH}{dT}T - H}{T^2} - \frac{\partial S}{\partial T}[/tex]
do I now substitute in dH?
Yes, I think if you put dH in it should come out in a similar manner to the previous one
okay, so:
dH = dU + pdv
[tex]\frac{\frac{dH}{dT}T - H}{T^2} - \frac{\partial S}{\partial T} = \frac{\frac{dH}{dT}}{T} - \frac{H}{T^2}[/tex]
[tex]\frac{dU + pdv}{dT}}{T}[/tex]
[tex]\frac{dU}{dT}T + pT\frac{dv}{dT}[/tex]
okay, so:
dU = Tds + pdV
[tex]\frac{Tds + pdV}{dT}T + pT\frac{dv}{dT}[/tex]
[tex]{T^2\frac{ds}{dT} + pT\frac{dV}{dT} + pT\frac{dv}{dT}[/tex]
[tex]{T^2\frac{ds}{dT} + 2pT\frac{dV}{dT}[/tex]
I think something has gone wrong here.
Try starting over except this time use G=U+PV-TS. Do the exact same to this as you did for F=U-TS.
okay,
G=U+PV-TS
G/T = U/T + PV/T - S
[tex]H = -T^2 \frac{\partial (U/T +PV/T - S)}{\partial T}[/tex]
quotient rule (1):
u = U, du/dT = dU/dT
v = T, dv/dT = 1
[tex]= \frac{\frac{dU}{dT}T - U}{T^2}[/tex]
quotient rule (2):
u = PV, du/dT = d(PV)/dT
v = T, dv/dT = 1
[tex]= \frac{\frac{d(PV)}{dT}T - U}{T^2}[/tex]
thus:
[tex]H = -T^2(\frac{\frac{dU}{dT}T - U}{T^2} + \frac{\frac{d(PV)}{dT}T - U}{T^2} - \frac{\partial S)}{\partial T})[/tex]
okay so far?
