Thermodynamic Identities Proof - Gibbs and Helmholtz
32 replies · 11K views · last reply
TFM said:
okay,
G=U+PV-TS
G/T = U/T + PV/T - S
[tex]H = -T^2 \frac{\partial (U/T +PV/T - S)}{\partial T}[/tex]
Okay let's go from here;
[tex]G/T=U/T+PV/T-S[/tex]
[tex]d(G/T)/dT=\frac{\frac{dU}{dT}T-U}{T^{2}}+\frac{T(V\frac{dP}{dT}+P\frac{dV}{dT})}{T^{2}}-\frac{dS}{dT}[/tex]
Now let dU equal it's identity again let P be constant, simplify and rearrange. Should get you to the answer. All my d's should be partial d's.
So:
[tex]d(G/T}/dT=\frac{\frac{dU}{dT}T-U}{T^{2}}+\frac{T(V\frac{dP}{dT}+P\frac{dV}{dT}}{T ^{2}}-\frac{dS}{dT}[/tex]
dU = Tds + pdv
[tex]d(G/T}/dT=\frac{\frac{Tds + pdv}{dT}T-U}{T^{2}}+\frac{T(V\frac{dP}{dT}+P\frac{dV}{dT}}{T ^{2}}-\frac{dS}{dT}[/tex]
so:
[tex]d(G/T}/dT=\frac{T\frac{ds}{dT} + p\frac{dv}{dT}T-U}{T^{2}}+\frac{TV\frac{dP}{dT} + TP\frac{dV}{dT}}{T^{2}}-\frac{dS}{dT}[/tex]
Pressure is constant, so can get rid of dP
[tex]d(G/T}/dT=\frac{T\frac{ds}{dT} + p\frac{dv}{dT}T-U}{T^{2}}+ TP\frac{dV}{dT}}{T^{2}}-\frac{dS}{dT}[/tex]
Does this look okay?
[tex]d(G/T}/dT= T\frac{ds}{dT} + p\frac{dv}{dT}T-\frac{U}{T^{2}}+T(V\frac{dP}{dT}+P\frac{dV}{dT}}-\frac{dS}{dT}[/tex]
Sorry I made an error,
This,
[tex]\frac{T(V\frac{dP}{dT}+P\frac{dV}{dT})}{T^{2}}[/tex]
Should be this,
[tex]\frac{T(V\frac{dP}{dT}+P\frac{dV}{dT})-PV}{T^{2}}[/tex]
