Thermodynamic Process that Produces the Most Work
The discussion revolves around a thermodynamic problem concerning different compression processes (isothermal, isobaric, adiabatic, isochoric) and their associated work output. Participants are examining the implications of the problem statement and the definitions of work in thermodynamics.
  • Participants are questioning the ambiguity of the problem statement regarding the definition of "work" and whether it refers to work done by or on the gas. There are discussions about the area under the curves for different processes and how they relate to the work done in compression scenarios.
There is an ongoing exploration of the definitions and implications of the processes involved. Some participants are reconsidering their initial thoughts based on diagrammatic representations, while others are clarifying the conditions under which the processes are analyzed. No explicit consensus has been reached, but there is a productive exchange of ideas.
Participants note that the problem's wording may lead to different interpretations, particularly regarding the use of prepositions in the context of work. The requirement for diagrams to accurately represent the processes is also highlighted.
sd17
Do you think my lecturer is correct in saying this is the correct answer? Question: For a given starting pressure and volume, which of the following compression processes requires the most work to reach a final volume: Isothermal, isobaric, adiabatic, isochoric?
delta(U) = Q - W
You have just posted the model answer. In the homework sections you are required to provide your own arguments and reasoning. So you seem to disagree with the model answer, why?
The reason I chose isobaric is because of the diagrams that I have seen in textbooks and other sources where it appears that the area under the curve is greater than other processes.
  • Wow
The question is about compression, you might want to draw that diagram again, where all the processes start out at the same volume and pressure, and the volume decreases, while the pressure increases.
To build a bit upon that. In the diagram you have attached, if you consider the curves curves for compressions (i.e., going right to left along the curves), then they all end at the same volume and pressure. However, the problem statement tells you that the processes should all start at the same volume and pressure, which makes the analysis different.
It is however questionable that the problem statement calls an isochoric process a compression process since volume is constant in such a process by definition.
Thank you for your input I am now able to see that adiabatic is the correct answer.
Thank you for your reply I am now able to understand the reasoning behind the correct answer.
sd17 said:
Homework Statement:: Do you think my lecturer is correct in saying this is the correct answer? Question: For a given starting pressure and volume, which of the following compression processes requires the most work to reach a final volume: Isothermal, isobaric, adiabatic, isochoric?
Relevant Equations:: delta(U) = Q - W
Am I the only one to think that the statement of the problem is ambiguous? I am always wary when I see "work" mentioned without reference as to who is doing the work on whom. Prepositions are particularly important in this case. If we compare the isobaric and adiabatic processes, the magnitude of the work done is positive regardless of whether the work is done by the gas or on the gas by the environment. The isobaric process has more area under the curve which makes the magnitude of the work (amount of Joules) exchanged with the environment greater than the adiabatic.
For a compression, the work done by the gas on the environment is always negative. A negative number with a larger magnitude is smaller, so the answer would be "adiabatic" because it is closer to zero than "isobaric". However, the reverse would be true for the work done on the gas by the environment and the correct answer would be "isobaric". Does "most" work in the statement of the problem mean "more Joules exchanged" or does it mean "the larger of two negative numbers"?
In my mind, the question is ambiguous because of the lack of prepositions. The only clue that we have is OP's relevant equation of the first law. One can tell by the negative sign that ##W## is the work done by the gas on the environment. However, many textbooks write the first law with a plus sign in front of ##W## which implicitly defines it as the work done on the gas by the environment. I think that in this case, the proper use of prepositions would have made the correct answer independent of which convention one uses for the first law.
No it does not. Not if drawn in accordance with the problem statement that specifies equal pressure and volume before compression, ie, the curves should coincide on the right side. The isobaric curve will lie below all the others.
Yes, of course. I should have drawn an actual diagram instead of doing it in my head. Anyway, I had my rant for the day.
  • · Replies 19 ·
