Thermodynamics and Entropy: Does an Atom's Energy Decrease Over Time?
cowcow8866
In the tropics, the water near the surface is warmer than the deep water. Would an engine operates between these two surfaces violates the second law? Why?
Clausius statement:
Heat generally cannot flow spontaneously from a material at lower temperature to a material at higher temperature.
I only knoe that the water near the surface is a high temperature reservoir and the deep water is a low temperature reservoir. Any engine only absorb heat at high temperature reservoir and do work and rejects heat at low temperature reservoir. I don't know what is the relationship of this with the second law. Thank you.
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html"
YES,...
But anybody can give me some hints or direction to tackle this question?
Note that from the mathematical definition of entropy, a process in which heat flows from cold to hot has decreasing entropy. This can happen in a non-isolated system if entropy is created elsewhere, such that the total entropy is constant or increasing, as required by the second law.
http://en.wikipedia.org/wiki/Second_law_of_thermodynamics"
Clausius statement:
The answer is no. So long as heat flows from the warmer reservoir to the colder, there is no violation of the second law.
AM
I have had a simple question that has nagged me since my '60s era physics classes. Simply put, does an an atom's energy "run down" over time? e.g. Is it a constant or does it drop over time due to entropy? If it drops over time, what is the lifetime of an atom?
