Does the Same Copper Cup Equalize Heat Loss Rates for Different Liquids?
The discussion centers on the heat loss rates of two different liquids, specifically oil and water, placed in identical copper calorimetry cups. It is established that while the copper cup has a fixed energy loss rate due to its constant dimensions, the rate of heat loss for the liquids is not the same due to their differing specific heat capacities. Newton's Law of Cooling is referenced, emphasizing that the cooling rate is proportional to the temperature difference between the liquid and the ambient environment, with a unique constant (k) for each liquid. The conversation concludes that while initial heat loss rates may appear similar, they diverge significantly over time due to the distinct thermal properties of the liquids.
  • Understanding of Newton's Law of Cooling
  • Knowledge of specific heat capacity
  • Familiarity with thermodynamic principles
  • Basic concepts of calorimetry
  • Research the specific heat capacities of various liquids
  • Explore advanced applications of Newton's Law of Cooling
  • Investigate the principles of calorimetry in thermodynamic experiments
  • Learn about heat transfer mechanisms in different materials
Students and professionals in thermodynamics, physicists, and anyone interested in the principles of heat transfer and calorimetry.
nithin
Ok hi guys,
recently i was doing a practical on thermodynamics. Then i came across of a question which was to comment on the assumption that the rate of heat loss for 2 different liquids , placed in identical calorimetry copper cups was the same.( the 2 liquids started off at the same temperature ( the liquids were oil and water)).
Ok my reasoning for the rate of heat loss being the same was that the copper cup,can only have a loss in energy at a fixed amount of power as the dimensions of the cup are kept constant. Please correct me if i am wrong.
Then i also commented on Newtons law of cooling( rate of change of temperature is proportional to the difference in temperature between the objects temperature and the ambient temperature) If it were to be written in a equation,it would be the (rate of change in temperature = -k(T - Troom) . Okay the k here is a constant which is different for every object.My reasoning is that to bring down the temperature of 2 different objects by a kelvin would require different amounts of energy as the the specific heat capacity of every object is unique. Furthermore the rate of energy loss is the same,hence 2 different objects would not have the same k value.As they would require different amounts of time to cool down. Please comment on these statements
well buyer beware as its free advice and i have never taken thermodynamics course.
IME its usually most fruitful to compare the most polar opposites possible, even where it may make little practical sense.
So into cup 1 I place water, well characterized, and the basis for the calorie unit.
Into cup 2, I pour the same volume from a neutron star, magically cooled to the same temperature but just as dense. Or a cup of magma.
Will the rate of heat loss vary? In the first instant, i should think not. In the second, maybe. By the twentieth instant, most assuredly. There is still a significant gradient with the container of enormous heat capacity, whereas with water there may not be. Thats why the Earth's core remains molten while we scrub our backs with pumice stone. So in essence I agree, very different rates of cooling and heat flux thru the container as a fx of time.
