Thermodynamics - Entropy&Heat dispersion
This discussion centers on the calculation of entropy and temperature averaging in a partitioned vessel containing helium at different temperatures (398K and 298K). The final temperature after mixing is calculated to be 348K using the formula q=nC_{v}ΔT. The challenge arises in calculating the entropy due to the logarithmic term ln(0) in the integral for entropy calculation. Participants suggest using the Debye theory for heat capacity near absolute zero and breaking the integration range into smaller sections to avoid the logarithmic singularity.
  • Understanding of thermodynamics principles, specifically entropy and heat transfer.
  • Familiarity with the Debye theory of solids and its implications on heat capacity.
  • Knowledge of calculus, particularly improper integrals and logarithmic functions.
  • Basic concepts of phase transitions and their effects on heat capacity.
  • Study the Debye model for heat capacity and its application near absolute zero.
  • Learn about improper integrals and techniques for handling singularities in calculus.
  • Research phase transitions and their impact on thermodynamic properties of materials.
  • Explore advanced entropy calculation methods for gases and solids at varying temperatures.
Students and professionals in physics and engineering, particularly those focusing on thermodynamics, heat transfer, and material science. This discussion is beneficial for anyone looking to deepen their understanding of entropy calculations and temperature behavior in gases.
AbedeuS
Hey, just a small mathematical enquiry about why temperature tends to average out in, say a box of gases. Let's just use the standard "Partitioned vessel" view of it, with One side having 1 mole of Helium at..say 398k and the other side with 1 mole of helium at 298K. The heat capacity is (rounded up) 21 J/Mol K and I'm assuming it's the same over the temperature range.
Now to calculate the final temperature when both gases are mixed I'm just going to use q=nC_{v}\deltaT to find the total thermal energy then calculate for T:
q_{298K} = 1*21*298 = 6258J
q_{398K} = 1*21*398 = 8358J
So:
T= \frac{q_{298K}+q_{398K}}{2*21} = 348K
Now with the final temperature, and discounting any residual T = 0 crystal entropy the entropy of that mixture is calculated by:
\int^{398}_{0} \frac{C_{v}}{T} dT = C_{p}ln(\frac{398}{0})
Stuck here, ln(0) is not possible I did have a grand plan to try and prove it to myself but how do you deal with this part in the integral?
solve as an improper integral?
maybe, I haven't taken calc II in about 3 years.
This isn't a homework or coursework question by the way, it's just me enquiring (Directed at whomever moved it)
You take into account that the heat capacity at temperatures near absolute zero is not a constant. In the Debye theory of solids, for example, it is
proportional to the third power of the temperature, so C/T goes as the
square of T. Then you can do the integral.
So its:
C_p ln(398) - 0^2?
No, I don't think so. My suggestion was just to break the range of the integration into several sections: 0 to T1, T2, ..., 398. and I only addressed my remarks to the range near zero (the part of your post in bold print). Many (solid) materials follow an empirical law of the type
C= aT^3 + \gamma T
over a small range in the neighbourhood of absolute zero of temperature. (i.e. the range 0 to T1. In this range, you can do the integral, thus avoiding the problem of log(0).
The values of the constants in the equation above as well as the temperature T1 will depend upon the material you are considering. For most materials, you will also have to divide the range from T1 to 398 into several smaller ranges as well because 1) the above equation loses its validity and 2) there may be phase transitions which will also contribute (i.e. the heat capacity is not a continuous function over the whole temperature range). For example, for oxygen, the ranges are
0 to 14 K contributing 0.54 cal/deg
14 to 23.66 K contributing 1.5
phase change contributing 0.948
23.66 to 43.76 contributing 4.661
phase change contributing 4.058
43.76 to 54.39 contributing 2.397
fusion contributing 1.954
54.39 to 90.13 (liquid phase) contributing 6.462
Vaporization contributing 18.07
Total: Entropy of gas (T=90.13) is 40.59
For higher temperatures, you can use cp=7R/2, up to about T=298 K; at
temperatures above this, you need another empirical equation.
As you see, the calculation of entropy is not exactly trivial. For helium, it might be
less complicated but I don't really know. A final remark: I have only addressed myself to the question you asked about the integral in neighbourhood of T=0, not to the rest of your post. Maybe you don't need to consider the absolute entropy but only the
change in entropy from the boiling point to the higher temperature. In that case, you could simply reformulate the problem to avoid the lower temperature range(s)!
Would that work in your case?
