Thermodynamics; find the thermal energy
The original poster attempts to calculate the total thermal energy in a liter of helium and a liter of air at room temperature and atmospheric pressure. They express confusion regarding the role of pressure in the calculation, given that temperature is provided. The discussion revolves around the relationship between thermal energy and kinetic energy of gas particles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the formula for thermal energy, considering the translational kinetic energy of particles and the ideal gas law. There are attempts to relate thermal energy to pressure and volume, with some questioning the necessity of pressure in the context of the problem.
Participants are exploring different formulations for thermal energy and discussing the implications of the ideal gas law. Some guidance is offered regarding the degrees of freedom for different gases, but no consensus is reached on the interpretation of pressure in this context.
There is mention of the ideal gas law and its application to different gases, as well as the relationship between pressure, volume, and temperature. The discussion includes considerations of static versus dynamic cases in thermodynamics.
iScience
question:Calculate the total thermal energy in a liter of helium at room temperature and atmospheric pressure. Then repeat the calculation for a liter of air.
I'm just confused because i thought thermal energy only depended on the translational kinetic energy of the particles. So why do i need all the pressure if the temperature is already given?
the only equation that comes to mind is E(kinetic)=3/2kT
and ...maybe the gas law?..
where do i go from here?
Maybe this way:
U(thermal) = N*1,5kT
and the ideal gas law: pV = NkT
so E(thermal)=(3/2)NkT -----> E(thermal)=(3/2)PV? since N=PV/kT? and then i just plug and chug?
Yes, I believe so...
isn't a "PV" term dynamically associated with the pressure with respect to a change in volume? ie calculating the work done on a system from a PV diagram? (ie the area under the PV curve)
janhaa said:
Maybe this way:
You're missing something here. The correct formula for an ideal gas is
U = \frac{f}{2} N k T
where ##f## is the number of (quadratic) degrees of freedom. That is why you get a different answer for helium and air.
Yes, expansion/contraction work done by/on a gas is obtained from
W = - \int_{V_i}^{V_f} P \, dV
but ##PV## by itself is just the product of the pressure and the volume.
well what i was getting at was i thought that that quantity (PV) was the case where the P is constant (isobaric) but still a dynamic case where the Volume is changing. so basically i don't understand why the quantity PV is used for a static case.
Pressure doesn't have to be constant. The formula for work is valid even when ##P## varies, although this might make it complicated to calculate the integral (unless ##P## can be expressed as a simple function of ##V##).
Equations of state are equations that relate the different macroscopic observables of a system. In the case of a gas, these observables are ##P##, ##V##, and ##T## (for a fixed quantity of gas). For an ideal gas, the relation is exactly
PV = N k T
or
PV = n R T
Such equations of state also exist for more realistic gases: they are slightly more complicated, but again relate ##P##, ##V##, and ##T##, such that if you fix two of them you can know the value of the third.
As an example, if you measure the pressure inside a bicycle tire and know what the temperature is, then you can calculate the volume inside the inner tube. So you see, this has nothing to do with "dynamics."
This is the first response to this thread in over a year and a half. I am closing this thread.
Chet
  • · Replies 35 ·
