Thevenin Problem Homework: Find Current When RL is Short
  • Thread starter Thread starter erok81
    Thevenin
1 reply · 2K views
erok81
This one has a few parts, so let's start with part a. See attachment for circuit. I've got two drawings in the attachment. I'll label them A and B. Image A is the original circuit.
None.
My first step is to find set RL to open. I can use a voltage divider equation and find the voltage to be 16V.
The next (which is where I am stuck) is to find RL as a short. Shown by image B. My professor wasn't the best in showing this as he used some trick I have no clue how solved this way.
I can find ITOT using...
[itex]I=\frac{V}{R} \Rightarrow \frac{24}{3+6//4}[/itex]
Solving for ITOT gives me 4.4A. My professor used this value and somehow came up with the current over the 4Ω resistor.
Then plugged it into..
[itex]R_{th} = \frac{V_th}{I_{short}}[/itex]
To find the Thevenin equivalent.
How does one find the current when RL is a short?
Did you mean for the parallel resistors in Diagram B to be 6R and 4R? They are labeled 6R and 3R currently.
Knowing the circuit series current allows you to determine how the current will split when it enters a parallel connection. The general way to do this is using the current divider formula:
[itex]I_{n}[/itex] = [itex]I_{s}[/itex] * [itex]\frac{R_{other}}{(R_{other} + R_{n})}[/itex]
Where:
[itex]R_{other}[/itex] is the total resistance of the other resistors, [itex]R_{n}[/itex] is the resistance which you wish to find the current through, [itex]I_{s}[/itex] is the current being divided and [itex]I_{n}[/itex] is the current you want to find.
