Thin Lenses Problem: Solving for $q=d-p$
  • Thread starter Thread starter Archimedess
    Lenses
The discussion focuses on deriving the relationship between object distance (d), image distance (q), and focal length (f) in thin lenses, specifically confirming the equation q = d - p. Participants agree on the correctness of the initial equations for image formation. The goal is to manipulate the equations to express d in terms of the other variables. The conversation emphasizes the importance of understanding the lens formula in optics. The thread concludes with a call for further manipulation to isolate d.
Archimedess
We try with a thin convergent lens, by moving it on its optical axis, to project on a fixed screen the image of a small object located in the optical axis. This is only possible with two position of the lens ##I_1=20cm## and ##I_2=80cm##. Determine the ##d## distance from the object to the screen and focal length ##f## of the lens.
##\frac{1}{p}+\frac{1}{q}=\frac{1}{f}##
##d=q+p##
Where ##p## is the distance of the object from the lens and ##q## is the distance between the image and the lens.
Since ##d=q+p \implies q=d-p##
\begin{cases}
\frac{1}{I_1}+\frac{1}{d-I_1}=\frac{1}{f}\\
\frac{1}{I_2}+\frac{1}{d-I_2}=\frac{1}{f}
\end{cases}
Is this correct?
Yes. Now manipulate until you have an expression for ##d##.
Likes wormbread and Archimedess
  • · Replies 16 ·
  • · Replies 18 ·
