This is how I solved this friction problem
  • Thread starter Thread starter SELFMADE
    Friction
3 replies · 2K views
SELFMADE
Wooden wall & block. Block=1kg. Block is pressed against the wall by force of 12N's on its lower edge from horizontal 20 degrees.
Will the block stay, go up, or slide down
Fnet = 12xsin30 - 9.8x1kg = -3.8
so block will slide down
should I have used wood friction constants too?
I don't know how to apply wood Uk Us. The block is press hozintally how would kinetic and static frictions affect vertical movement
Hey there SELFMADE :smile:
Perhaps you could post the enire question as it was stated? I am a little confused about what is being asked.
Were you given values of U_k and U_static in the problem?
Is it clear now?
http://img198.imageshack.us/img198/7676/pfsb.png
U_k and U_s aren't given but I figure since a table of coefficients was given in the chapter and problem specifically states "wood" it must be used.
Ok. The problem with your approach is that no, you did not include the effects of friction.
I suggest that you draw a free-body diagram with all of the forces that are acting on the block.
