This makes no sense, is my textbook dumb or I am trying too hard?
  • Thread starter Thread starter flyingpig
    Hard Textbook
The discussion centers on solving a linear system represented by an augmented matrix and the appropriate elementary row operations to apply. The matrix is already in triangular form, with the fourth equation providing a direct solution for x4. Participants agree that the next two elementary row operations should be R2 replaced by R2 + 3R3 and R1 replaced by R1 - 5R3, despite some confusion regarding the definition of elementary operations. The consensus is that the textbook's instructions are valid, emphasizing the need for clarity in understanding elementary row operations.
  • Understanding of augmented matrices in linear algebra
  • Familiarity with elementary row operations
  • Knowledge of triangular form in linear systems
  • Basic skills in matrix notation and manipulation
  • Study the concept of triangular matrices in linear algebra
  • Learn about different types of row operations and their applications
  • Practice solving linear systems using augmented matrices
  • Explore the implications of elementary row operations on matrix solutions
Students of linear algebra, educators teaching matrix operations, and anyone looking to deepen their understanding of solving linear systems using augmented matrices.
flyingpig
Consider this matrix as the augmented matrix of a linear system. State in words the next two elementary row operations that should be performed in the process of solving the system
\begin{bmatrix}<br /> 1 &amp; -4 &amp; 5 &amp; 0 &amp; 7 \\ <br /> 0 &amp; 1 &amp; -3 &amp; 0 &amp; 6 \\ <br /> 0 &amp; 0 &amp; 1 &amp; 0 &amp; 2 \\ <br /> 0 &amp; 0 &amp; 0 &amp; 1 &amp; -5 <br /> \end{bmatrix}
Solution from book
The system is already in “triangular” form. The fourth equation is x4 = –5, and the other equations do not contain the variable x4. The next two steps should be to use the variable x3 in the third equation to eliminate that variable from the first two equations. In matrix notation, that means to replace R2 by its sum with 3 times R3, and then replace R1 by its sum with –5 times R3.
I pretty much got it except this part R1 by its sum with –5 times R3
That doesn't even eliminate the -4 in the first row. Shouldn't it be R_{1} \mapsto 4R_{2} - 5R_{3}
I think the book is correct. It asks for two steps, and what you are suggesting is not an elementary row operation. I agree that the third step would be to try and eliminate -4 in the first row and you would do that by taking the sum of R1 and 4*R2. But again, the book seems to ask for only two elementary row operations.
Yeah, I did it in two steps
Step1.R_{2} \mapsto 3R_{3} + R_{2}
Step2. R_{1} \mapsto 4R_{2} - 5R_{3}
Like I said, the second step you're suggesting is not an elementary row operation. The following two are elementary row operations:
R_{1} \mapsto R_{1} - 5R_{3}
R_{1} \mapsto R_{1} + 4R_{2}
A combination of them, on the other hand, is not. So you need to go in steps, you can't add or subtract more than one (multiple of a) row when talking about elementary row operations. What you suggest is a row operation, just not an elementary one.
But that doesn't solve the matrix then
Well, yeah, two steps of applying elementary row operations don't solve the system, three do. But the book quote you posted in your original post says to
... state in words the next two elementary row operations that should be performed in the process of solving the system.
Dumb book...thanks Ryker!
No problem :smile:
11K
