Thread Killer Champions: Franzbear & Moonbear
  • Thread starter Thread starter tribdog
    Thread
The discussion revolves around the humorous concept of "thread killers" on a forum, where participants analyze who tends to end conversations with their posts. The top offenders identified include franznietzsche, Moonbear, and tribdog, with a playful tone suggesting a competition for the title of "thread killer." Participants debate the validity of counting last posts as a measure of thread-killing ability, arguing that it should be adjusted based on the total number of posts each user has made. The conversation shifts into a light-hearted narrative, likening thread-killing to a horror movie scenario, with participants playfully accusing each other of sabotaging discussions and attempting to "steal" the thread. The banter includes references to fictional scenarios involving dramatic rescues and humorous characterizations, maintaining a light and comedic atmosphere throughout.
  • #3,451
Hmmm, I do it differently. I hold the tops of my thumb and middle finger together tightly, holding both rigid, with my index finger pointing up and my ring finger & little fingers bent so that they touch the palm of my hand. Then I snap my middle finger down quickly so that it hits the "mound" on the palm where the thumb base is.
Sounds more complicated than it is. Matt, probably easier to have someone show you.
  • #3,452
I think I do it in a way that combines both Evo's and BicycleTree's method :biggrin:. Mostly it just requires lots of practice until it just happens. The pad of your thumb and middle finger (tip of the thumb meeting with the middle finger about halfway between the tip and first joint). Squeeze them together really hard, then quickly slip the middle finger toward your palm, bending it only at the middle joint (keep the finger somewhat at a right angle to your palm and don't change the angle of your knuckle while you snap). As you snap your middle finger straight downward toward your palm, divert your thumb slightly to the side toward your index finger and snap it up toward your index finger, which should be bent at the knuckle but held just a bit higher up than the starting point of your middle finger. Wash your hands to get some of the oils off your fingers first for best results (it's almost impossible to snap well if you just moisturized your hands or got oil on them or something like that).
  • #3,453
You're right, most of the noise does actually come from the ring or middle finger. If you press the thumb and finger together tightly enough then that will happen automatically; when the thumb slips one way the finger can't help but slip the other.
  • #3,454
I just put some peanut butter on my thumb and fingers to test that but I could still snap almost normally, only a little less loud. I think it's a matter of how hard you press the fingers together. The key, I think, is in pressing hard enough so that the thumb indents the finger enough for the fat to form a wall in front of the thumb, that the thumb can then suddenly jump over for maximum acceleration.
  • #3,455
im trying to learn pen spinning.. but my fingers just don't bend the right way.. or maybe its the technique?
  • #3,456
I'm not even going to ask why you decided to try the peanut butter thing. But, I think you're right about the key being the pressure between the thumb and finger. After sitting here snapping quite a few times to figure out exactly how to I do it to type out the instructions, my finger is a bit sore from pressing it so hard into my thumb (or from resisting the pressure of my thumb against it).
  • #3,457
I have never learned pen spinning.
  • #3,458
I never learned to do that. One of my friends in 8th grade was really good at it, and I tried and tried and tried, but could never do it. I just managed to get stares from the teacher from dropping my pen so much. :-p
  • #3,459
Peanut butter for oil, of course.
My fingers do not hurt no matter how long I snap because they have protective and strengthening webbing between them. Seriously. It makes my fingers appear disproportionately short, although they are normal length measured from the knuckles.
  • #3,460
I think I know why i suck at it. every person who does this has skinny long fingers..
mine are short and plump towards base and can never make a full 90 degree between index and middle finger :frown:
  • #3,461
Cronxeh, which way do you mean? I can make almost a 90 degree angle if the index finger points straight ahead and the middle finger folds at the knuckle towards the palm, but if I try to do it reverse (middle straight, index bends at knuckle) the most I can make is about 45 degrees.
  • #3,462
well 'almost' in your case is roughly 65-70 degrees in mine, when index points straight parallel to your arm and middle pointing downward
  • #3,463
:smile: Um, okay, that wouldn't have been my first choice. Did you just dab your finger in some oil that separated out? Otherwise the peanut butter itself it sticky; it might even help with snapping.
Oh, do you know how hard it is to not take this bait? :-p
  • #3,464
Hmm...I can do a 90 degree angle both ways. Though it's easier the first way. But, yes, I do have long, skinny fingers. I don't know if that matters though. I know people with little stubby fingers who can still snap.
  • #3,465
i can make a cracking sound when i make a fist though :biggrin:
also my toes crack.. my fingers crack (sideways too), knee caps
  • #3,466
Cronxeh, about 70 degrees is what i meant by "almost." My middle finger is only about 3/4 as long as my palm because of the webbing. I credit the webbing with my fast typing speed.
Moonbear, I stockpile empty jars of peanut butter for no reason--the natural kind, too, where the oil separates on its own and when you first open it there's about a half centimeter layer of oil. It was really the closest thing at hand.
  • #3,467
I think that shorter fingers and more webbing probably is an advantage, not a disadvantage, at snapping. When you want to produce the maximum finger tension I think it's helpful to have tissue closer to the fingertip for better leverage. It would be a disadvantage at pen spinning only.
You know what's weird, is that my toes have cracked from time to time, and frequently my spine pops and snaps, but never, ever have I cracked my fingers, intentionally or unintentionally. They are almost noiseless except for snapping.
  • #3,468
Have I scared everyone off?
  • #3,469
Nope, I just got distracted by a homeschooler posting on another site. She's one of those annoying people who can't stop bragging about her children, but she "forgives" the youngest for not being as smart as his siblings. Yes, she uses the word "forgives." :bugeye: She's also convinced that the cure for math phobia is to make a kid just keep doing a problem over and over and over again and not move ahead until they can get all their assigned problems 100% correct, because the only cause of the anxiety is the frustration of getting the problem wrong. :confused: And franz thinks the politics forum here gets his blood pressure up. :rolleyes: But she provides endless fodder for jokes at her expense among the people I email from that site.
  • #3,470
Well, you know, personally I think that the basics of math are important to get down 100%. I think a big problem with some students is that they "decide" they can't do math, which means they won't try. My sister was like that, she'd quit before even making a good attempt at a problem. If you stick with it until you master the material it's good.
On the other hand, sometimes you don't learn something fully until you use it in other ways. So there is an argument for moving on, with the new material as motivation for mastering the old material. But if there is actual frustration and anxiety on the current material then that's not likely to happen; the student should stick with it until the anxiety goes away. If the student is capable of learning the material, that will happen eventually.
  • #3,471
I'm thinking you and Cronxeh are too young to be popping and cracking when you walk! I used to be such a horribly chronic knuckle cracker. My grandmother insisted it would give me arthritis. :smile: Sometimes my right wrist pops...I think that's because of an old injury, because it was really bad nearer to when I injured it, and has been steadily improving. Nevermind that it's been over 10 years since I injured it! In retrospect, I might have wanted to see a doctor about it at the time, but I thought it was just a mild sprain. I think it was actually slightly dislocated and it suddenly felt amazingly better one day when I had no choice other than to use it for lifting something really heavy, and suddenly it just popped and immediately felt better. Only I could get better by overusing an injured limb. Other than that, just my neck cracks. Some people find that a bit disturbing.
Though I pulled something in my shoulder last night trying to move a microtome in the lab. It's a really old one, and I swear it must be made of solid lead. It's not very big, but it's heavy. I'm not even sure how heavy it is. Must be 80 or 100 lbs. After I moved one, I barely had the strength to tip the other up on just one end (I needed a clean work area, and the absorbent padding under them hadn't been changed in so long it had turned from white to dark yellow ). I always forget how heavy those things are because I don't move them often. I have to remember to do these things when someone else is around to help lift. Oh well, it's going to be a cold, rainy weekend anyway, so can't do any yard work even if I didn't have an injured wing.
  • #3,472
Yeah, my spine crackles frequently. Not when I walk, but if I flex my back muscles or stretch I can feel and hear the vertebra snapping around. Also, my shoulders tend to dislocate easily when I throw things, but they always chunk right back into place immediately (not that it doesn't hurt for a week or two afterwards...).
  • #3,473
Oh, I don't think we disagree there. Concept-wise, yes, you really need to master the basics to move on, but she's talking about redoing a homework assignment until all the answers are perfect. You know, like when you make a dumb mistake and multiply 3X3 and get 6 :rolleyes:, well, she would make the kid do the whole assignment again if they did that.
But that's what I really think most of math phobia is, that the kids have decided they can't do it before they ever get into the classroom. I can see being persistent and not letting them get away with just not doing it, because of course that's what a lot of kids with math anxiety do, they just don't do the assignments. But I don't think sitting them down with a sheet of problems that makes their mind go blank and gets them sweating and making them sit there until it's done is going to help; I think it would just make them get more anxious. Anyway, she's not a rational person anyway. She usually presents an argument that is internally inconsistent (she almost always makes at least two points in her arguments that are necessarily mutually exclusive; like we should have the government give all kids school vouchers and privatize all schools to get the government out of the education business). Meh, I don't really want to discuss her here, it was just where I went for a while and got distracted too long by her lack of logic.
I tend to think most math anxiety is just a learned behavior from parents or other students or teachers even. But, as I did some googling on it, it sounds like math teachers are finally catching on that they need to do something different in the classroom to address this problem, something that will give these kids some confidence. And, imagine this, they're suggesting they stop teaching kids by rote memorization and start explaining the concepts! I can't believe that's a novel idea!
  • #3,474
Well, careless errors do not warrant revisiting the material. One thing the student could do is check his/her work. I never used to like doing that and I would lose about 10% credit on careless errors despite fully understanding everything, but now I always do it, and I make very few careless errors. Also it has to do with age; I think that up to a point, the older you get, the fewer random mistakes you make, a function of practice and normal brain aging.
If the student only makes careless mistakes yet has a math phobia anyway, I think the student should start learning more advanced material.
  • #3,475
More like an inverted Gaussian distribution I suspect. After a certain age, you hit your peak and it's all downhill from there. Though, I'm not quite yet convinced there isn't an absent-minded professor gene that is conditionally turned on by something added to the food at the faculty cafeteria. :-p
  • #3,476
No, I don't mean just general mental ability, I mean not making random mistakes. I would guess that random mistakes are caused by the same rushing signals that cause the creativity and fast learning of youth; when these signals begin to decrease, there is less interference and processes are less prone to error, although general mental ability would play a role.
  • #3,477
I don't even know what a Gaussian distribution is, other than that it should have something to do with magnetism.
Please... whoever this ***** is, let me loose on her. It's because of people like her, but in the public school system, that I have only a grade 9 math level. Ironically, two of my favourite subjects are astrophysics and quantum mechanics. Theoretically, you can't understand either one without advanced math, but I seem to do okay.
  • #3,478
Sorry, I was just being fancy for the physicists. It's just another name for a normal curve (bell curve).
While a few people have tried to play nice and seek some agreement with her, most of that entire board is letting her have it. But at least since she homeschooled her kids, she wasn't showing up for any PTA meetings, so she's only screwed up her own children (I'm sure they are screwed up, just based on the sum total of her views). I mean, how can that youngest one be normal if he's only being "forgiven" for not doing as well as his siblings? Then again, maybe he's the sane one who rebelled against mom, and that's why she thinks he hasn't done as well, because he didn't follow her plan. :smile:
  • #3,479
AFAIK: Gaussian distribution = normal distribution = social scientists' "bell curve"
*prepares to be jumped on by mathematicians*
  • #3,480
Well, Mathworld told me that the Gaussian was the normal distribution, but what is an inverted Gaussian??
