Joze
- Messages
- 2
- Reaction score
- 0
So I've been stuck on this exercise for a few hours now, maybe you can help out:
3 balls meet at the same height hm.
Ball 1 is accelerated straight up into the air for 1s from height 0.
When the acceleration stops, ball 2 is launched straight up from height 0 with v2 = 29.358 m/s.
A short time later ball 3 is dropped from height hc=60m.
Each ball has a mass of 1g. The height hm is the maximum height that ball 1 reaches on its flight path.
Friction can be neglected.
1) calculate hm and the acceleration a of ball 1.
2) what is the time between the moment, that ball 2 is launched and the moment ball 3 is dropped from the ceiling hc=60m?
Kinematic equations for constant acceleration
I defined:
t0 as the time that the acceleration of ball 1 stops and ball 2 is launched with v2 = 29.358 m/s
t1 as the time that ball 3 is dropped from the ceiling = ?
t2 as the time at which all balls are at height hm = ?
hm as the height at which all balls meet = ?
h1 as the height at which the acceleration of ball 1 stops = ?
hc as the height of the ceiling = 60m
v1 as the velocity of ball 1 when the acceleration stops = ?
v2 as the initial velocity of ball 2 = 29.358 m/s
Then I tried to come up with kinematic equations for all 3 balls:
- Ball 1:
eq1: hm = h1 + v1*t2 - 0.5*g*t22
eq1.1: v12 = 2*g*(hm-h1)
- Ball 2:
eq2: hm = v2*t2 - 0.5*g*t22
- Ball 3:
eq3: hm = hc - 0.5*g*(t2 - t1)2
I wrote the height of ball 1 as a function of time:
h(t) = -0.5*g*t2 + v1*t +h1
The height at which the balls meet is the max point of the function above so I set the first derivative = 0 and solved for t:
h'(t) = -g*t + v1 = 0
So t = v1/g which should be t2
I tried out plugging that into equation 1 and 2 and I also tried to set eq1 = eq2 to solve for something, but from that point I just went in circles and I just can't figure out how to proceed. Maybe I'm blind to something obvious because I've been trying for so long to solve this.
I would really appreciate any help or hints on how to go on from there.
Thanks in advance for your time.
